Question about 3Com EtherLink III Combo Network Adapter
Vertical/horizonal I was cleaning my keyboard when I hit something that changed the view on my monitor from the normal horizonal to vertical so I have to turn my screen sideways to work with it. Can you please help? It's a Dell 1907F
    Genius:
  • 1,554 Answers
There is no button on the monitor that sets this that I can find.
it is likely you changed the rotate settings for the video somehow.
If you have an ATI video card.
you should see an icon for ATI on the tool bar by the time and date .
right click on it and choose catalyst control center. in there you will find the rotate desktop.
if you don't see the icon then you can find it under start/programs/catalyst control center
Posted on Feb 25, 2008
My Toshiba M55 Laptop has a vertical 'ribbon' of flickering. Is it fixable?
Maybe your screen is going bad or the video card inside the computer is going bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the vertical ribbon then your lcd screen is bad and your video card is good. If the Borrowed monitor displays the same vertical ribbon as your lcd screen then your video card inside the computer has an issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Toshiba Satellite M55-S329 Notebook
The screen has lines and double vertical images then horizonal black lines form and no image is there - a virus?
there is no virus. the problem is the screen. you need to replace it with new screen or let if fix by a technician. they will replace the vertical and horizontal transistor. or so.
Mar 05, 2010 | Acer AL1715 17" LCD Monitor
View is vertical not horizantal
Ctrl-Alt-Up Arrow key
Or look in Control Panel>Display>Adapter settings for settings specific
to your video card.
Jun 25, 2009 | Computers & Internet
Screen went horizonal from vertical
To get back the original, try this
Use the following Key combination : Ctrl Alt UpArrow
If this does not work, then see if you can minimize all applications and see the desktop. Then right click anywhere on the desktop and select "Graphic Options" and then "Graphic Properties". A window will open and click on "Rotation" tab and then select "Normal". Now click on "Apply" Your screen will return to normal.
Apr 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Horizontal display
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Cheers
Gund
Mar 30, 2008 | LG Studioworks 775N 17" CRT Monitor
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
3Com EtherLink III Combo Network Adapter Logo
41 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
