Question about Car Audio & Video
CLUSTER PROBLEM FORD CHANGED MY CAR CLUSTER CAUSE IT WAS GIVING ME PROBLEMS THE OLD SPEEDEOMTER READ 20 SOMETHING THOUSAND AND THE NEW ONE CAME WITH 0 READING NOW THEY CANT PUT IT ON THE AXACT READING SO I CAN KEEP UP WITH MY SERVICE RECORD
  • 2,039 Answers
They can put to the millage you whant but i think its not by the law its illegal to change the millage im a mechanic and belive me changing millage is easy but not legal
thanks for using fixya
pierre
Posted on Feb 26, 2008
Good Day, the cluster shows that the tank is empty. It has been fueled to maximum.
the dash fuel gauge should be ok
if the dash computer fuel reading cant be reset
ring or pop into an audi service centre to ask advice
at worst
re new or re calibrate fuel tank sender and float
Sep 03, 2016 | 2011 Audi A3
Fabia 1.4 MPI ECU problem?
I really doubt that the problem is the PCM (ECU), that is the least likely thing that would cause these codes. The causes will take a factory manual and good test equipment that can read live mainstream engine and sensor data.
Mar 12, 2014 | Skoda Fabia Cars & Trucks
Gmc problems
If you replaced the cluster, the tach was replaced. So its probably not a problem with both the old and new tach. Its probably a problem in the wiring to the tach. Put a multimeter across the tach signal wires on AC setting, rev the car, does the meter reading change?
Dec 21, 2013 | Cars & Trucks
'04 Dodge Ram 3500 Diesel. I pulled the instrument cluster to try and replace a burned out bulb; much to my surprise there are no "bulbs" in the cluster, just something that look like soldered...
Sounds like you have a wire grounding out somewhere, or could be in the new cluster you put in. Check all your connections in the wiring, you could put the old cluster back in to see if it corrects your speedometer then you would know if its the "new" cluster you just put in giving you problems or whether you pulled a wire loose replacing the cluster.
Hope I was of some help to you. Good luck
Mar 24, 2011 | 2004 Dodge Ram 1500
99 Ford Escort ZX2 Speedometer/Odometer doesn't work
I'm sorry, I have to ask, this is an automatic right? That out of the way, Does the trans shift different when you drove it with the Vss unplugged when you had the ohm meter on it? 8.5 volts? Something sounds wrong here. I'll have to look up the wiring diagram before I can say thats a bad reading but it should be battery voltage (14 volts running) or 5 volts?
Jul 08, 2010 | 1999 Ford Escort
Im buying a motor at the junk yard it has 98000 miles do i need to buy the odometer or just the icm so i know how many miles are on the motor im buying i dont want to have my old odometer reading since...
It is illegal to change the Cluster or modify the odometer reading , unless the mileage on the cluster in your car now is documented, the mileage and date of the new cluster when installed is also documented. You do not have to change the cluster just because you change the motor. The mileage only is there for the vehicle not for the engine. Hope this helps, Not sure if you were asking about the legal aspects. Cobra.. :-)
Jun 12, 2010 | 2002 Ford Explorer
2005 Mustang all of my Gauge readings are going crazy. Says I am going 70 when I am going 30 the tachometer goes way below 0 in the wrong direction. And the temp gauge reading is always on c.
On the 05 Mustang instrument clusters this is a common problem, it's caused by failing stepper motors on the cluster's circuit board. It can be fixed though, check out this page for more on how to get it repaired - 05 mustang instrument cluster repair
Jan 10, 2010 | 2005 Ford Mustang
My tach and speed dont read right
Common issue with the 05 Mustang instrument clusters, it's caused by failing stepper motors on the cluster's circuit board. It can be repaired, check out this page for more on how to get it fixed - 05 mustang tachometer doesn't work
Jul 12, 2009 | 2005 Ford Mustang
Ford focus 1.8
anyone that can afford to code read for free needs there head looking at my equipment has cost me thousands of pounds and returned me a lot more !!!!!! does the rev counter do funny things as well ? ...
Oct 15, 2008 | 2000 Ford Focus
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
