Question about Equinox (210120)
THUMPING SOUND WHEN STARTING,SATRTER OR SWITCH STICK,DRIVER WINDOW STUCK UP,PULLY,DRIVER BELTS AND TENSIONER HAS BEEN REPLACE 5 TIMES,CD STUCK IN PLAYER WILL NOT EJECT..
I HAVE CONTACTED CHEVROLET CUSTOMER SEVICE AT 1-866-790-5700 OVER 100 TIMES.THEY HAVE DRAGGED THEIR FEET AND HAVE DONE ABSOLUTLEY NOTHING TO REPAI,WITH AL;L THIS PROBLEM I HAD TO FIAL A LEMON LAW LAWSUIT,AND A COMPLAINT WITH THE BBB AUTO-LINE THEY IN TUEN IN OVER A YEAR HAVE DONE NOTHING VEN TO BRING MY CASE TO AN ARBRITRATOR.
    President:
  • 1,509 Answers
Solving problems of this nature requires me to know what kind of car. Rember the (big City) dealers have bigger service departments and have more specialists that may have already come across your problems and fixing them on other cars. The service writer is there to get you signed in and to tell you what hes going to do and the charges involved and doesnt nessarily know if his techs can fix the problem unless they can cite examples of other cars they fixed and how they came out. Some noises are normal and the cheaper the car was as new the more likly that it will have some anoying but normal nioses
Posted on Aug 10, 2009
My mazda protege keeps breaking alternator belts. I've put on serval alternator belts, a new water pump pulley, and 3 alternators and my is still breaking belts
Replace belt tensioner, any other pullys, I worked on ? vehicle where the pully would spin but would stop every so often.
Dec 31, 2015 | 2000 Mazda Protege
The power steering is out and I can hear a pulley going bonkers. There is a squealing sound like a belt isn't catching, and also an oscillating sound like a pulley is loose and moving back and forth or...
i am having a similar problem. my power steering pully is loose. im pretty sure i have to replace the pump and the pully however my power steering still works but the belt squeals.check all the pullys they drive the belt or belts. its usually always either the tensioner thats the pully that allows you to remove the drive belt or the power steering pully which sucks the most because you must remove the entire power steering pump to replace the pully and since you have to go through all that trouble you might as well replace the entire power steering pump as well. i am not a mechanic so try and find more information.
Jul 26, 2010 | 2002 Hyundai Accent
2000 subrau belt replacement, outback ,how to replace
there are three belts, depending on which belt just loosen tensioner center bolt then loosen adjusting bolt that runs behind tensioner pully, reverse order to tighten new belt, all belts are done the same.
Dec 13, 2009 | 2000 Subaru Outback
Remove water pump
Disconnect battery earth lead. Do not turn crankshaft or camshaft whn timing beld removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of rotation (unless otherwise stated) Do not turn engine via camshaft or other sprockets. Observe all tightening torques. Remove engine, remve RH engine mounting. Remove auxiliary drive belts, water pump pulley, crankshaft pulley, timing belt upper cover, timing belt lower cover. Turn crankshaft clockwise to TDC on No. 1 cylinder, slacken tensioner bolts 5 & 6. Move tensioner away from belt and lightly tighten bolts. Remove timing belt. Remove water pump and replace with new one. Suggest to replace cambelt as well.
Installation
Ensure timing marks aligned3 & 4. Fit timing belt in anti-clockwise direction, standing at crankshaft sprocket. Ensure belt is taut between sprockets on non-tensioned side. Slacken tensioner bolt 5. slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner bolt 6. Tighten tensioner bolt 5. Turn crankshaft on turn clockwise. Ensure crankshaft sprocket timing marks aligned 4.
Slacken tensioner bolt 5. Slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner 6. Tighten torque: 20 - 26 Nm. Tighten tensioner bolt 5. tighten torque: 20 - 26 Nm. Apply thumb pressure to belt at middle. Approximately 5kg. Belt should deflect to 1/4 of tensioner bolt head width 7. Belt tention can also be set using burroghs (BT-33-73F) tension gauge 10 at middle. Turn crankshaft 90 ° anti clockwise. Check belt tension is 9.5 16,5kg (engine must be cold). Install components in reverse order of removal. Fit cranckshaft pully. Tighten crankshaft pully bolts 8. G4-J: Tightening torque: 12-15Nm.
G4-N/G4-k: Tightening torque: 10-12Nm
G4EA: Tighten crankshaft pully bolt 9. Tighten torque: 140-150Nm.
Nov 04, 2009 | Hyundai Excel Cars & Trucks
How i fix timing of lantra 1600 cc 95
Disconnect battery earth lead. Do not turn crankshaft or camshaft when timing belt removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of ratation unless otherwise stated, Support engine. Remove, engine mounting, auxilliaty drive belts. Water pump pulley 1. Crankshaft pulley bolts 21. crankshaft pully 2. timing belt covers 3. Turn crankshaft to TDC on No 1 cyclinder. Ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket and balancer shaft sprocket timing marks aligned. Timing marks on camshaft sprockets should align with cylinder head upper face. Dowel pins on camshaft sprockets should face upwards. Slacken tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove, automatic tensioner unit bolts. Automatic tensioner unit. Timing belt, crankshaft centre bolt, crankshaft sprocket. Crankshaft sprocket guide washer. Slacken blancer shaft belt tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove balancer shaft belt.
Installation
Ensuring timing marks arligned. Note timing marks on camshaft sprockets should align with cylinder head upper face. Exhaust sprocket mark is on recess, but inlet sprocket mark is on tooth. Note: to check oil pump sprocket positioned correctly, removing blanking plug from cylinder block. Insert 8mm diameter Phillips srcrewdriver in hole. Ensure screwdriver is inserted 60mm from face of cylinder block. if screwdriver can only be inserted 20mm: turn oil pump sprocket 360°. Insert screwdriver again. Fit balancer shaft belt in anti-clockwise direction, starting at crankshaft sprocket. Slacken balancer shaft belt tensioner bolt. Turn tensioner clockwise to tension belt. Tighten bolt to 15-22Nm. Apply thumb pressure to belt. Belt should deflect 5-7 mm. If not repeat tensioning procedure. Install crankshaft sprocket guide washer, crnakshaft sprocket. Tighten crankshaft cente bolt. Tighten torque:110-130 Nm. Note ensure crankshaft sprocket guide washer is fitted correclty. Oil treads and contact face of crankshaft body before fitting. Check tensioner body for leakage or damage replace if necessary. Check pushrod protrusion is 12mm. If not replace automatic tensioner unit. Slowly compress pushrod into tensioner body until holes aligned. Resistance should be felt. Place flat washer under tnesioner body to avoid damage to body end plugs. Retain pushrod with suitable pin through hole in tensioner body. install automatic tensioner unit to cylinder block. Tighten bolts to 22-27Nm. Fit timing belt in anti-clockwise direction, starting at the tensioner pulley. Slacken tensioner pulley bolt. Turn tensioner pully clockwise to temporarily tension belt. Tighten bolts to 43-45Nm. Turn crankshaft slowly 1/4 turn anti-cockwise. Turn crankshaft clockwise until timing marks alligned. Slacken tensioner pully bolt. Fit tool to tensioner pulley. Tool No 09244 28100. Apply clockwise torque of 2,6-2,8 Nm to tensioner pulley. Tighten bolt to 43-45Nm. Insert special tool in timing belt rear casing. Tool no 09244-28000. Screw in tool until pin can be removed from automatic tensioner unit. Remove special tool. Tool nr 09244-28000. turn crankshaft two turns clockwise. Wait 15 minutes. Ensure timing marks aligned. Check extended length of pushrod is 3,8-4,5mm. Install components in reverse order of removal. Tighten crankshaft pulley bolts, Tighten torque 20-30Nm
Nov 01, 2009 | 1995 Hyundai Elantra
Rattle noise from tensioner and pullys aera when engine is idiling and warm
Take a candle and rub all belts, do NOT get your hands stuck between the belts BE CAREFULL or use silicone spray. Try this first, sometimes the belts dry out and make noise, other wise the idler pully bearing is at fault.
Aug 10, 2009 | 2005 Ford Focus
199 dodge caravan 3.3 tensioner
yes you must jack the vehicle up put it on jack stands for safety, and around the power steeirng pump under neath you will see the nut that is holding it you will need a long extension and a swivel.
should be 15, 14, or 13 mm
when installing the belt itself, you must put it on the idler pulley last that is the other smooth pulley, otherwise it will be a bear to get on. good luck.
Mar 09, 2009 | 2000 Dodge Caravan
Had the belts break and come off engine, top center pulley damage
the belt that turns the alternator is called the serpentine belt. this also usually runs your fan and is sometimes also called an "accessory belt"
If you look down at the belt area, you will see a pully toward the front of the car that looks like it's attached to an arm. That is the tensioner pully. The tensioner is spring loaded. If you look at the arm of the tensioner there should be a square hole in it to insert a socket wrench or a breaker bar/pull handle to use as a lever to remove the tension from the belt. If there is no hle, then use a wrench(possibly 15mm) on the bolt head of the pully itself as your lever. As you hold the tensioner out of the way, unloop the old belt. Pay attention to the routing, so you can reinstall the new one correctly. Then, you route the new one in and again use your lever to move the tensioner so you can get the belt over the last pully. I usually put it over the alternator last. Use a light to make sure the belt is fully on all 5 grooves of every single pulley before you start the car.
You can also go to chilton.com and look at your cars manual
Jan 05, 2009 | 1991 Ford Escort
Equinox (210120) Logo
Top Equinox Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Equinox Computer and Internet Expert? Answer questions, earn points and help others
