Question about LG 37LC7D 37 in. LCD HDTV
LG 47" LCD TV - 47LC7DF Clicking Noise
My TV has a clicking noise when I first turn it on but after about a minute the clicking stops. I also am having problems with the sound. I have an HDMI cable from the cable box to the TV and then two RCA plugs from the Audio Out on the TV to my Samsung home theater system. Sometimes the sound just goes away. I tried connecting two RCA plugs from the cable box directly to the home theater system and the sound works fine.
My LG also clicks when I turn it on and or off, this thing is only 4 days old. Do I need to take it back or what?
  • 1 more comment
  • AZKarol Mar 02, 2008
    Our 37" LG HDTV has a box that comes on when it is first turned on that says,,,,,DVI/HDMI output is blocked...then under that it says Press EXIT to cancel.....well we have tried that and it doesn't work. It goes away in about 30 seconds and then the set plays well.....Any solutions? AZKarol
  • Anonymous Mar 14, 2014
    back light is lit. but front fades and sometimes i can reboot cable box and it works
  • Anonymous Mar 24, 2014
    When turning on my LG TV with my ATT&T digital box, the Home menu keeps turning on. After exiting, the home menu continues to turn on.
  • 1,554 Answers
The old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Posted on Feb 25, 2008
How do you get the tv to connect with the wireless internet router?
The manual is here if you need it:
After perusing the manual, it looks like the TV may not have a network capability...
wired or wireless
Jun 09, 2011 | LG 47LC7DF 47 in. LCD HDTV
Problem for LG 47LC7DF 47 in. HDTV LCD Television it just flashes red and takes a couple of minutes to turn on and makes a popping sound..
television just flashes red and takes at least 15 minutes to turn on after turning off and on and makes a popping sound.
Apr 24, 2010 | LG 47LC7DF 47 in. LCD HDTV
Lg tv no sound or picture, blinking green light but back light on
The common problem is the main board, instead to purchase a expensive main board, you may try to re-flow the soldering on the main board, it is the only way you may fix the main board at your home.
Re-Flow Soldering Procedure for LG Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Oct 28, 2017 | LG 47LC7DF 47 in. LCD HDTV
I have a shadow on my 47" LG LCC7DF HDTV LCD TV
This is usually caused by dirt trapped between the lcd filter layers and appears when the screen is pressed, pressing the layers togehter producing an internal dust smear..This can only be removed by stripping the lcd down and cleaning the filter layers
Oct 17, 2009 | LG 47LC7DF 47 in. LCD HDTV
47LC7DF Powering up issues
Some of these LG models have ben recalled due to faulty power boards. You might want to check it out on the net
Aug 28, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Aug 08, 2009 | LG 47LC7DF 47 in. LCD HDTV
My tv stays on for a few minutes and then just turns off. The red power button flashes and I can't turn it back on. I have to leave it for some time before it turns on again and it just does the same thing...
Seems to be a common problem with these 47 LG models. There were some models recalled recently ny LG. If you contact LG and comlain about this problem ypu may be able to have it fixed Its faulty control boards
Jul 29, 2009 | LG 47LC7DF 47 in. LCD HDTV
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
LG 37LC7D 37 in. LCD HDTV Logo
313 people viewed this question
Computer Repairing
Computer Repairing
