Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp Printer 1551
We have an error message H-4 flashing on our display. Can you tell us what that means?
  • karen47 Feb 26, 2008
    Thank you we did that and the display cleared. But now it shows CH. Any ideas on what to do next? KAB
  • Anonymous May 06, 2008
    aftrer an electric cut . H 4 flashing ! what should i do
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Feb 26, 2008
  • Rick Kasper Feb 26, 2008
    Thats normally a underheat error or a low voltage condition. Try the above routene, It will work 95 percent of the time.
    CH is the toner cartridge is empty. Or the chip on it is bad.
    Right now can't find my documentation. I am 90 percent sure its the toner, 10 percent chance the drum.
Printer driver for sharp al-1551
You can download the printer driver from the Sharp WEB site.
http://www.sharpusa.com/customersupport/productdownloads.aspx
Apr 03, 2012 | Sharp AL-1551 Laser Printer
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Sharp AL 1551CS copier flashing '4' 'H'. Will not clear. This is a stand alone unit, not connected to a computer. How do we clear
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Sharp AL-1551 Laser Printer
E 7 error on the screen
You have problem with your laser unit ( LSU ), you should replace it
Jun 03, 2009 | Sharp Office Equipment & Supplies
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Nov 16, 2008 | Sharp AL-1551 Laser Printer
Sharp AR-5316
May 12, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
enter the following code.
cancel -- interupt -- zero -- interupt - the display should switch off then enter 14 and push the copy button- copier should reset if not heater lamp could be blown
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
