Question about Carrier 52PQ307 Wall/Window Air Conditioner
Carrier Thru-Wall Heater and Air Conditioner won't heat
Have a carrier thru-Wall Heater and Air Conditioner model #52SQ502294 and it no longer produces heat. Over the summer, the air conditioner wouldn't work. I then tried the heat, it came on but then quickly the heat stopped with fan still blowing. Took the cover off to discover that the filter needed to be cleaned. After cleaning the filter, the air conditioner worked but the heater would not produce heat.
  • 2 more comments
  • Carolyn Aug 11, 2013
    I didn't mean through wall air conditioner I meant wall mount air conditioner. Thanks
  • Anonymous Mar 16, 2014
    I need an operators manual for a carrier 38VNO481120A air conditioner
  • Anonymous Mar 22, 2014
    where can I find disposable filters for a carrier heat pump?
  • Anonymous Mar 31, 2014
    The air conditioner stop after a few minutes and show F8 on the panel
  • 552 Answers
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
Carrier quietline air conditioner
do you have a remote control? from there click mode until it is on heting
Jul 27, 2014 | Carrier Heating & Cooling
Want to know how many btu lca061p
Carrier LCA061P 6050 BTU Thru-Wall/Window Air Conditioner
Jul 11, 2012 | Carrier LCA061P Air Conditioner
To ublock the drain at the back of the unit
Sometime the water gets condensate by cond.coil heat. Excessive water will be drained out thr' pipe to b connected with hose in the unit.
Dec 13, 2010 | Carrier (52PE315) Thru-Wall/Window Air...
American standard thru-wall heater air conditioner (PTEC1501GAA) will not heat. When wall mounted thermostat is turned up for heat, the fan turns on but no heat comes out. I opened it up and checked the...
sounds as if the heater coil itself is burnt out. These coils may be repaired if you can get an universial coil repair kit and rewire the heater coil yourself. Since the age of the unit is in question I don't know if it is possible to get a kit for repairs but you never know. I would check an a/c supply house for this kit. Good Luck on your repairs
Nov 03, 2009 | Carrier 52PQ307 Wall/Window Air...
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
I have a 51GR Carrier window air conditioner and the
Power off (Disconnect)
Push together "Temp up" and "On/off" and reconnect power while pushing.
Jun 14, 2009 | Carrier 38CKC042 Air Conditioner
Carrier 52PQ307 Wall/Window Air Conditioner Logo
2,096 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
