Question about Sanyo PLC-SW30 Multimedia Projector
No Power Hi.. there is no power light in my projector
  • 75tbird May 23, 2009
    I found a sanyo plcsw30. It worked for a few days. It had been on for a couple hours today and it was pretty warm. When i adjusted how it was sitting i bumped it slightly, and the light whent off, now the power light wont come on at all.
  • terminalspin May 11, 2010
    I don't know how to find the plug fuse or the pj fuse. Any suggestions
  • 43 Answers
The problem is common with sw-35/sw-30. They have a built in temp. sensor, that opens the current circut(doesnt allow current) as the unit gets hotter. Its a little pot like thing, with a white tip on the inside of the projector, next to the lamp. All you have to do it push it down with a screwdriver (GENTLY) and it will restore the power circut. With the projector off ofcourse.
Here is the full repair/service schematic. Should help you ALOT!! it helped me. :)
http://yama.co.za/forum/index.php?topic=146.0
Posted on Dec 03, 2009
Sometimes its not the fuse it might be the funny 14C471capacitor that has not mean anything or is very rear to find that's why everyone is now turning away from Sanyo unlike remember Amstrad PC those years? Sanyo seems to be in the same line. You better watch out this manufacturer. Got to Sanyo's that are dead no spare parts if you don't trust me check ebay and see how many are there that are sold as spare parts.
Posted on Sep 26, 2009
You need to check the hoser attachment
Posted on Feb 09, 2009
  • 27 Answers
Check mains fuse in plug
check mains fuse inside pj
Posted on Feb 26, 2008
Power light flashes
Hi Sir,
did you solve with your trouble?
perhaps the trouble is on the mainboard,
Dec 12, 2011 | Optoma EX532 DLP Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have replaced the lamp to my projector, but still doesnt work. Power light and bulb lights are still red.
Hello C navor hi, my experience with projectors, tells me that there is problem with the power supply section, Have it check for short on the regulator section, this could be anything from bulging capacitors, open resistors or the power regulator, the red means that there in no power going to the main board and the power supply section is on standby.
Aug 03, 2010 | Toshiba Office Equipment & Supplies
Projector not booting up
The projector may not be receiving power or it may be malfunctioning. Turn the projector off and unplug the power cord. Confirm the power cord is securely connected to the projector and then plug the cord back in to a different outlet and turn on the projector. If this does not solve the problem, and another light is on or flashing, check the projector’s status.
Hope this helps
Apr 01, 2010 | InFocus IN24 Multimedia Projector
Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Feb 08, 2009 | Philips Hopper SV20 Impact Multimedia...
My LP 750 is dead
Hi there
This sounds like a faulty Mainboard - could you supply me with your country and the part number on the Mainboard ?
May 12, 2008 | InFocus LP 750 Multimedia Projector
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
VP100 Projector Powers Up But Doesn't Light Up
Well, If you are pushing the power button beside the lens and the fans speed up but no light is on hte lights might of gone out as of now i have the same projector no one has a replacement bulb but if the fans just go steady and does not speed up when you power it on the there night be a problem with the button try the remote if you have it otherwise it just might be the bulb,
Hope This Helps
Jan 20, 2007 | Lightware VP 100 projector lamp Projector...
Sanyo PLC-SW30 Multimedia Projector Logo
282 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
