RCA 52" TV
I previously got a response from this page but can't find the part # given to me. (A fuse and soldering wires?)I have an RCA 52" the screen appears in 3D and when turned on or off, a blue, red and green line appear across the screen.
  • jgmcd4 Nov 28, 2008
    I have the same problem. TV is 2 years and 3 months old. I called a repairman who over the phone said it was the transformer or something like that. (very bad english) Quoted a repair price of between 300-600.00. Any ideas on possibly fixing this myself.
  • 2,326 Answers
Here is your other post.
Posted on Feb 25, 2008
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try Ebay.com to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wm24 the tv has double vision and shadows , then goes black screen. I unplug it for 10 - 20 min . screen still distorted
HELLO AM RICO, I WORK ON TVS SOMETIMES. ON THIS MODEL OF TV ITS COMMON FOR COLD SOLDER AROUND THE FLYBACK, CHECK THE FLYBACK, IF THERE IS COLD SOLDER AROUND THE FLYBACK. YOU NEED TO RESOLDER THE FLYBACK AND REPLACE A 5 AMP PICO FUSE. IF YOU NEED MORE HELP PLEASE FEEL FREE TO CALL ME AT 602-810-7149 I LIVE IN MESA AZ
Dec 31, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca 52'' projection tv model p52937
Go to menu ,now to setup when in set up do you see convergence? If convergence is missing in menu it is a open fuse,only it does not look like fuse ,They look more like small square capaitors brown, they will be right next to flyback transfomer FL231 (3) of them in a roll it will be the middle one,you can take needle nose plyers and pull top up on fuses.
Dec 17, 2008 | RCA D52W19 52" Rear Projection Television
Tv won't stay on
The first thing I would do is to check the solder connections on the flyback transformer. This is a common problem with this set
Dec 05, 2008 | RCA HD52W59 HDTV Projection Television
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
Do we need a new TV?
I dont think this problem can be fixed without solder work or part replacement of convergence section. Its no just matter of fuse. You should get repair facility from concern service center because TV has dangrous voltages inside and qualified person knows how to deal with TV.
Jul 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
