Question about Brother IntelliFAX 2800 Laser Fax
Blank vertical stripes on incoming faxes
I have blank stripes on my incoming faxes. I changed the toner and drum which helped some, but I have 2 fairly wide stripes remaining. I have also cleaned the glass and 'white bar' as per instructions in the manual. HELP!
  • OCLisa Feb 25, 2008
    I went through these steps again, I had already done them as I mentioned and I still have stripes. Any other suggestions?
    Thanks.
    Scholar:
  • 159 Answers
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Posted on Feb 25, 2008
  • Rob Fauchon
    Rob Fauchon Feb 25, 2008
    It must be the laser unit then. The unit is located on the bottom of the machine, held in by 2 screws. Also 2 connectors. You can only obtain spares from an authorized Brother dealer. Brother will only help you to find the nearest dealer.
Incoming faxes are blank outgoing faxes work ok. toner has been changed
Hello sir; Try to make a copy, if copy is OK then replace a new phone cord .if copy not OK still blank, that's means high voltage supply board have problem.
Oct 12, 2009 | Canon L120 Fax Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black vertical Stripe
Move the blue slider on the drum cartridge side to side 10 times.
Jan 30, 2009 | Brother IntelliFAX 5750e Laser Fax
White vertical line on received faxes
hi,
The upper glass is under the drum unit.
- Remove Toner and Drum Unit and you will see the glass. Try to clean it.
Bye.
Dec 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Copies and incomming faxes are blank
Take your drum unit out and inspect. It just might be out of toner. Look at the silver pins that contact the drum unit.
Apr 22, 2008 | Brother IntelliFAX 5750e Laser Fax
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Brother IntelliFAX 2800 Laser Fax Logo
256 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
