Question about Sentry Fireproof Safe
I can't seem to unlock my safe Sentry 1250.
I have the combination, but can't get it to open. It has worked in the past.
What is my problem?
  • 5 more comments
  • ahillyer Mar 19, 2008
    it just wont open. i might have the wrong combonation.
  • janetlr2000 Jan 03, 2009
    my dad died, left the combination for us, but we cant get it open. it seems that handle doesnt want to turn. help
  • Wonel Jan 05, 2009
    I can no longer get into my safe put in numbers and it will not open
    Not very old batteries good my code is the original never changed it Model #ksw3632
  • juicyjenny Feb 17, 2009
    i pressed the red button by accident iside my safe and i think i reset it but it wont open when i put my code in
  • marincontact Apr 22, 2009
    i have a saga safe d posit box , but lost the combo can you help?
  • Anonymous Mar 16, 2014
    how do you open a sentry 1250 without the combnation
  • Anonymous Mar 21, 2014
    cant unlock my safe....took all the advice, and will not do...comb..36 to right 54 left, 97 right
Also make sure you are executing the combination in the right steps... For mine (a three-number combo), these are the steps that work:
* turn the knob to the LEFT, pass 0 at least THREE times and stop at the first combo number
* turn the knob to the RIGHT, pass 0 ONCE and stop at the second comb number
* turn the knob to the LEFT and go directly to the third combo number (do not pass 0, do not collect $200)
Posted on Aug 24, 2008
Just cracked my 1250 safe. If you've already got it open, take the plastic cover off with a flat head screwdriver. You'll expose the combination mechanism. Spin the combination wheel clockwise three times, then turn it until the notch on the wheel closest to the door meets with the latch. Write down the first number. Turn it counter clockwise once around then do the same with the second wheel. Finally turn the third wheel clockwise until the last notch matches up with the others. Write down all three numbers and you have your combination.
Posted on Jul 11, 2008
  • katie8706 Feb 07, 2011
    does the safe have to be open to do this?
I have a small safe i lost my key 2 mountes ago i need it opean
Posted on Apr 07, 2010
  • 113 Answers
You have to contact Sentry directly to get help on that.
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Posted on Mar 05, 2008
The customer service at Sentry is the absolute worst! They will not answer any questions regaring opening your NEW safe without paying $25 first. No if, and, or but's! I told them I had just bought the safe and the instructions didn't work, she (Heather) got rude and repeated she needed $25 or she'll get fired. What a joke. So, the trick is to use the 0 as your set point. So, if stated 3 times to the left make sure you pass the 0 three times then go to your number.
DO NOT CALL THE (419)483-4852
Posted on Oct 12, 2009
4 Suggested Answers
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: I can't seem to unlock my safe Sentry 1250.
Locksmiths agree sometimes even with the green light the safe’s batteries are not strong enough to retract the latch. Try replacing them with some new alkaline batteries
Posted on Aug 09, 2010
SOURCE: how do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
Sentry safe 1250 lost combination
I have a sentry safe 1250 .83 cubic and I have the key I was using the safe for awhile without the combination and just the key but now the key wont work and someone messed with the combination part which I dont know the combination i dont know what to do and I dont wanna trash this safe
Dec 12, 2017 | Sentry Home Security
Have acquired a Sentry 1250 Fire safe (appears pretty old) with the door open but have no combination. How can I learn that combination or how can I reset it?
Safer to get a locksmith safe technician to rest it for you as if you get it wrong the safe will lock and won't open
Jan 15, 2017 | Sentry Home Security
How to change combination of model 1250 sentry fire safe
dear sir i was given a sentury safe#1250 ,serial #g969560 the safe is open how do i figure out the combination?
Feb 08, 2013 | Sentry Fireproof Safe
Need to open sentry 1250 safe without combination
As you cant look up the combination without the serial number. Your only alternative is to call a locksmith to drill it open or ship it to
A1-Locksmith prepaid freight and ill do it for free.
Jan 31, 2013 | Sentry Fireproof Safe
How do you open a sentry 1250 combination safe? I have the number
Jun 06, 2010 | Sentry Fireproof Safe
Know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Feb 28, 2009 | Sentry Fireproof Safe
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Nov 16, 2008 | Sentry Fireproof Safe
Jul 13, 2008 | Sentry Fireproof Safe
Need assistance opening my Sentry 1250 safe. I have combination but do I start at 0 and pass the first number then stop 2nd time around at first number then go straight to the other 2 numbers?
Locksmith instructions for sentry safes
on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Pull the handle down; cracking sentry safe open.
May 06, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
20,868 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
