Question about Sony Handycam DCR-TRV18E Mini DV Digital Camcorder
I cant put a tape in!
Hello
my tape deck wont open!
it pops out of the cam' but doesn't open to allow me to put in a tape, then goes back inside the cam'
please help
thanks
hugo
  • 10,594 Answers
When mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Posted on May 31, 2008
  • chapinha0306
    chapinha0306 Oct 02, 2012
    but it keeps doing it everytime i wanna eject the tape.. is there a permanent solution for it?
Cassette door will not open in my Pioneer CT-A9
Hi Russell,
Sound to me like another cam operated mechanism. I just had a Nakamichi brought to me the other day with the same symptoms.
If you turn the unit on and listen closely, you might hear a motor running inside, this motor is running because it is trying to initialize the deck mechanism. The reason it can not is that a cam belt that goes from the motor to the pulley that operates the cam is loose, broken or turned to goo. These belts just do not pop in and often require the deck be taken apart a ways to get to the belt. There is also lubrication and cleaning of old grease out of cam gears and slide plates. This is where a Technician is needed. I am in the Chicago area in case you need my help- If you are in New Jersey I can give you the name of another business. Please advise of your location and we can go from there.
skywavebe@sbcglobal.net
Aug 15, 2012 | Audio Players & Recorders
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Audio Players & Recorders
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
I have a Sony Handy cam DCR-HC30. When i put a cassette in, it says (reinsert the cassette).
-make sure that your tape is clean and dry
-clean the tape head inside the tape deck if you have a video head tape cleaner
*tape head: the one that reads the tape inside the camcorder.its the metal thing at the bottom inside the tape deck.
-or you can use a soft and dry Q-tip to clean it(dont use any liquid cleaners)
*or if confused where the tape head is....just clean all metal parts inside the tape deck and make sure you do it lightly with a soft dry Q-tip.
Jun 05, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Tape goes in but then pops back out
This is because the tape carriage is not able to take the tape fully into the threaded position. If you have young children in the house, remove the lid & check that there are no "objects" inside. If not, then the deck mechanism is possibly out of alignment & would need to be repaired.
May 27, 2009 | RCA Televison & Video
Bmw casette
Hello.
You need to take out the cassette deck from the car. open the cassette deck by removing the various screws, once open, there is a small plastic gear which you need to wind manually which will slowly release the cassette.
Oct 26, 2008 | 1999 BMW 323 Series
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
DC Motor turning continously in Cassette Deck
yes this is normal. the deck utilises what is called a rolling transport and the motor runs continiously to allow for mechanical cam engaged functions to work.
Dec 08, 2007 | Audio Players & Recorders
Sony Handycam DCR-TRV18E Mini DV Digital Camcorder Logo
326 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
