Plug & Play does not work with my new portable Elements 160GB hard drive!
I have plugged in the above unit activated Backup and my computer just sits there searching for a backup device!
Please help
Derek
  • Delboy67 Feb 26, 2008
    Unfortunately the item came with no software or driver information - the impression was gained that it really was "plug & play" - I remain stumped but thanks anyway.
    Regards
    Derek
  • 55 Answers
You will still need to install the software & drivers that came with the backup device for it to be recognized as such by the PC.
Posted on Feb 25, 2008
Rename toshiba external hard drive
Check to see if there is a file in the root directory called "autorun.inf". If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
Mar 19, 2012 | Toshiba Canvio 500 GB USB 3.0 Portable...
How do I install CNM Core 120GB portable Hard Drive USB2 0 on my laptop?
The hard drive is plug and play, no software is required. All you have to do is plug the hard drive into a USB slot. If it doesn't work then you know the hard drive is bad and you would have to get another one.
May 28, 2011 | Computers & Internet
I have an imation /Apollo 2.5PHDD 160GB and it is not recognised on my computer...how do i reinstall if i dont have the disc etc.what else could be the problem
Hi there.
I have this same HDD and I don't think your problem is related with any "installation" or softwares. It should work just as a plug-n-play hardware, as mine does. Maybe Ooq Affiat's advice would do, by changing the USB cable. Best luck!
Feb 10, 2011 | Imation Apollo UX 2.5" USB Portable (250...
MY COMPUTER DIED. HOW DO I TRANSFER THE FILES FROM MY VERBATIM SMARTDISC FIRELITE 160 GB, USBFLB160' TO ANOTHER COMPUTER? THANKS...........................JOHN NICKERSON
It depends on how you copied your files to the SmartDisk.
If you used the "normal" method of copying files/folders in Windows, then just connect it to the new computer.
If you used some "backup" software from Verbatim to write "backup" files,
then you'll need to install that software on the new computer,
in order to retrieve from those "backup" images.
Nov 13, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Driver does not install atomatically
With the computer off, plug the unit in to the computer and turn it on.
Now start the computer, there is no driver to install manually, windows
uses generic drivers to detect plug n play devise's.
Out of hundreds of computers, the only time I have not seen a hard
drive detected was because the hard drive was bad, and the others
where hacked versions of windows, called lite xp, or the chipset drivers
where not loaded because someone just installed windows but nothing else.
You can look through your bios for plug n play, but its probably set to auto.
Most external HD's take a while to be detected from 10 seconds up to a few minutes.
If the driver does not install automatically, what driver are you installing
that you get it to work ??????????????????????????
Feb 08, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I have a hard drive with all my pictures on it and my computer not reading the hard drive when it plug in how can i send it in to get it fix it a smartdisk 160gb
Always try the simple first- connect the drive to a different computer, then if that does not work, try a new cable to the old computer then to the different computer. If still No Go, many local big box retail stores like Best Buy have a computer repair desk. Be prepared for $$ charge, however.
Dec 09, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Portable hard drive got yanked out computer and isn't working
try cantacting your suvice provider or where you got it from
Oct 15, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
