Question about Dell Latitude C640 Notebook
Battery not charging?
The battery will not charge when its in, i get a flashing light with my battery LED the sequence is 4 green flashes 1 orange. i have no idea what is going on, iv looked up a couple of sites and found out that a fair few people are having the same problem.
Thanks
  • SFYoda Feb 25, 2008
    brought it off ebay. the AC works fine without the battery and iv tried moving the battery to the second port but still no luck... i was thinking i could try to replace the cell's of the battery but i need to get the right amount of change else it may explode...
  • 55 Answers
Replacing the cells on a laptop batter is nigh-impossible to get right. It sounds to me like there's a short in the battery itself, or perhaps one completely dead cell in there. In either case the best/cheapest/easiest solution is to get a new battery for it.
Posted on Feb 25, 2008
Sounds like a dodgy charger. go bk to place were u gt it from and get it changed.
Battery Light Flashes Orange My battery light is flashing orange (4 times)
Does the battery hold charge for long?
THe flashing means not charging..
test another power adapter or change battery
Sep 18, 2013 | Lenovo 3000 N100 Notebook
Tip
Dell Portable Battery LED flashes Orange 4 times then Green once
This LED flash pattern, Orange, Orange, Orange, Orange, Green (Repeats) indicates a internal failure of the Battery. Pressing the charge indicator button on the battery (If equipped) will give a 1 3 5 LED on indication which also indicates a failure in the battery.
The battery may still function, but at less than optimal performance and will have a progressively shorter functional life until it dies.
The only way to resolve the issue is to replace the battery.
on Dec 23, 2009 | Computers & Internet
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Latitude d505 not charging
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Jan 31, 2009 | Computers & Internet
Dell battery problem
Hi Roy,
Dell, apparently have had some problems with their batteries, as they called back some, including yours.
Goto Dells homepage here and goto -> a bit down this page -> Step 1: Is your battery model affected?
Hope your battery is among these, as you will be able to get a new one.
regards
/Teis
Dec 17, 2008 | Dell Latitude D600 Notebook
The LED sequence indicates a failure in the battery. (Like one cell has low charge) As long as the overall battery output meets the minimum for system operation, the battery will work.
The average lifespan for a Portable battery is about 500 discharge/recharge cycles (1 to 2 years) anything after that is a bonus
Replace the battery, issue will go away
Nov 18, 2008 | Dell Inspiron 6000 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Dell Latitude C640 Notebook Logo
135 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
