Question about Saeco Incanto Classic Espresso Machine
Water fill light stuck on
Hello.
I filled the water tank as prompted by the light and then made sure the machine was primed - filled a cup with water through the steam wand but the machine will not reset itself. I've tried turning it on and off many times.
Any suggestion would be appricaited.
Thanks!
L.
  • 1 more comment
  • ljabc Feb 25, 2008
    Thanks very much - I'll try as soon as I get home. It was very nice of you to reply so quickly!
    L.
  • ljabc Feb 26, 2008
    Thanks!!! It worked!
    L.
  • java mumma Mar 08, 2008
    I have been away and when I returned the water was almost empty and the water light was on. I filled tank and tried to prime machine as the light was still on. A tiny bit of water came out of wand and that was it..light was still on and couldnt make cofffee....any ideas?
  • 2,039 Answers
You say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
thanks for using fixya
pierre
Posted on Feb 25, 2008
Is the 'add water' button on the keurig devised to add extra water to the already filled cup? I like extra water, a weaker coffee, is there a way to add extra water to the cup?
Hello, this ad feature is telling that you need to ad some water to your reservoir. If you are not getting a full cup of java then here is some things to look at that would help this problem.
Here is a list of things you can do to try and resolve the problem.
Descale the coffee machine....
White vinegar is recommended, but it seems like lemon juice works just as well or even better. Also there are many different commercially sold products to descale coffee machines. One of these is a product called CLR which seems to do a great job. Some people have even used their denture cleaner to descale the coffee brewer. Dissolve a couple of tablets in water and place in the reservoir... then run the solution through the coffee machine to clean it.
Another common problem is that foil from the K-cup lid will get stuck in the needle that punctures the top of the K-cup. Like wise the bottom needle can also get coffee grounds or other debris stuck inside it. Scale from the descale procedure can also be a problem. To get the needles clean the best thing to use is a paper clip. Do not use a toothpick as that can break off inside and cause greater problems. Bend the paper clip so that approximately 1" is straight. Then insert the paper clip into the needle and wiggle to clear any debris. On some brewers the K-cup holder can also be removed, the bottom will twist off to reveal a nozzle that also has small holes that will plug up. Cleaning these holes may be the ticket to a great cup of coffee again.
Check to see if you have water running back into the reservoir when you are brewing a cup of coffee. If you have water bypassing, then you have a problem, there should be no water returning to the reservoir if the brewer is working properly. To stop this from happening there are a few things that you can do.
. You can hold your finger over the white tube in the top of the reservoir to place more
pressure on the water to flow through the needle and expel the debris from the tubing.
Take a can of compressed air like you would use to clean your computer and blow air through the tube(s) in the reservoir and also the needle(s) to clear dirt debris and water from the machine. This process may make a mess so be sure to have the machine is a place where the mess can be cleaned up easily. Some have even used a large tire type air compressor out of desperation, and report that it does work. I would use great care with this method and shoot the air in very short bursts.
      Often the pump gets air in it and does not prime correctly. It will then only pump a little water. To fix this you may need to get rough with the machine. Slamming the reservoir onto the machine will sometimes work, The shake rattle and roll method also will have the desired affect sometimes. Some have turn the machine upside down over the sink, have slapped the sides of the machine, or even shake the machine to get the air out of the lines.
      Once you do get the pump to prime properly, you can keep the pump from getting more air by making sure to fill the reservoir before it gets empty by using a pitcher to fill the tank instead of removing it and filling it.
With some K-cups, the bottom needle does not pierce the bottom of the cup if you simply place the K-cup into the holder and then close the top. Extra effort may be needed to make sure that the K-cup gets seated properly so that the water can flow through the K-cup easily. If you have water still in the K-cup when you remove it after brewing, you are having this problem.
Thank You, Please rate my free help. Appreciate it.
Oct 13, 2011 | Keurig B60 Coffee Maker
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
"Fill water tank" prompt
this has happened to me too just yesterday (26 May 2013), I replaced the tank because I was lucky to have kept the spare bits off the old machine I had and it worked fine. Over time, the water gets into the float and corrodes the magnet. Best to just replace the magnet if you can or the whole tank. Good luck
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
S-Class Incanto Sirius
Hi Erika,
Make sure the magnet in the water tank flow up when you fill the water tank.
Open the steam knob and make a cup of water to see if you can make a full cup of water.
if nothing of this help you then i think you have to replace the flow meter in your machine.
Have a nice day.
/Mirran
Aug 11, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Fill water tank problem
Do you have a magnet in the left corner in water tank? if you had it, make sure it float up when you fill the tank with water.
If you not have a magnet, try to open the steam knob and see if you can get a full cup of water, if it stops with half cup then the "water turbin" has to be replaced.
Jun 24, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco coffe maker doesn't work
Thank you for your concern! I drove it over to place nearby that fixes these machines in Los Angeles. That way, I can avoid costly shipping charges!
May 24, 2008 | Saeco Vienna Digital Coffee Maker,...
Fill tank
ok on the bottom left side( from the front) is a magnet in the water tank. Sometimes that gets stuck and the sensor wants you to fill.
it can also be that the machine needs to be primed
Mar 27, 2008 | Saeco Vienna De Luxe Espresso Machine
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Saeco Incanto Classic Espresso Machine Logo
365 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
