Question about InFocus ScreenPlay 4805 Multimedia Projector
Powering down When I try to turn the projector off with the remote it says it is powering down but never completely goes off.
I think you mean that you can still hear the fans running after shutting down, this is normal with the X family of projectors including the SP4800 and SP4805.
Posted on Mar 08, 2008
Infocus 5700 will not power on
Try re-installing the driver for the projector. It might help.
Jun 29, 2012 | InFocus ScreenPlay 5700 Multimedia...
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
NEC LCD1760V shuts power down after 3seconds
Hi Ron usually power down issues are caused by faulty power supplies especially if the projector looses power completely however the logic board could be protecting itself if it detects a fault such as a fan not working either way it is not recommended that you try to fix it yourself unless you know what you are doing, but it may be worth removing the cover and checking that the fans are working and connected properly, occasionally the lamp can be at fault especially if it has been used for many hours if the projector tries to power up and you see light through the lens and then it looses power its probably the psu at fault, if it powers up then goes into standby of fault then its most likely a logic issue. I hope this helps Regards Ant
Nov 30, 2011 | NEC Office Equipment & Supplies
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Won't turn on
If you're NOT still under warrantee you should at least open the projector and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the remote to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your projector serviced. good luck!
Dec 28, 2005 | Gateway Projector 210 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
49 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
