Sanyo VPC-E760 Digital Camera Logo
Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sanyo 1292 camera will not charge. the battery has been dead for months and will not charge at all now. what can be wrong with it?
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Feb 14, 2010
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
933244
Points
7369
If the battery is more than a year old you probably nbeed a new one.
My Sanyo VPC-T1496R camera is dead. What is wrong?
It depends on what type of battery it uses. Some batteries once they have fully discharged are not able to recharge
I have a Sanyo VPC T1060 camera and its not
The Sanyo VPC-T1060 does not support in camera charging. You need to charge the battery with the supplied battery charger.
Sep 14, 2014 • Cameras
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
1helpful
I bought a sanyo e15005tp and i charged it once and then used up the battery once i saw the battery was almost dead i tried charging it but the camera turned off with the lense still out now it wont...
Well, for starters, the camera can be defected, because you said that when you charged the battery, it said it was on low, correct? So you should probably send it to the manufacturer, Sanyo, and they might give you a new Sanyo camera, since you got it defected. BUT first, you should call, and ask for more reference. Secondly, just see cheap deals on eBay, & Amazon, so buy a new battery. If you find that you DID charge it, than the Camera itself is defected. But their is also a chance that your area you charged it in IS either too hot or too cold, causing the battery pack to take longer, and lose the battery itself. Hope this info. helps!
1helpful
2answers
The battery for my sanyo digital camera won't charge.
I had this same problem with my Sanyo. I went on E Bay and purchased a new battery.. It was about 8 dollars and shipped from China. But it worked when I put the new battery in and charged it.
Hi There, I have a Sanyo Xacti E1BL waterpoof digital camera which is just over 12 months old. I have just gone to use it and nothing! Will not even take a charge. Completely dead. Can you advice
Hey sue9268,
I would first try cleaning the battery contacts. If this doesn't work then this problem is most likely caused by either a faulty battery pack or battery charger. Most retailers that sell cameras should have a charger that you can test your battery pack on, and if the battery pack tests out fine then you should probably purchase a new charger. Of course if the battery pack is bad then you should purchase a new battery Pack. If none of this works I would have your camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
