Since a paper jam the other day, our phaser 6110 mfp will only print blank pages, and will continue to print blanks until the job is manually canceled. This happens regardless of the type of document, whether printing or copying, etc. Any suggestions?
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
There are some small spots on the "seal" glass. It is the 3/4 inch wide strip under the scanner, not the main glass. Clean that strip well, I suggest taking some rubbing alcohol and just a regular piece of paper, crumpled up. Use that to clean that strip vigorously.
That will take care of it.
Check the following information....... http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513 or most of the time for a paper jam, there is a QUEUE of papers waiting to be printed. id take out the usb cable via the back of the computer {the one that connects to the printer} go into the control panel, look for printers, double click on that, find the printer, it should say {working offline} right click that, choose the uninstall/delete opts. turn off the printer. reboot the machine, wait until it boots all the way up. take the printer, turn it on, then plug back in the usb cable to the back of the machine. if it is windows either xp/vista it will auto find the usb cable and install automatically. you can then go back to the control panel, printers and it should be listed in the directory. try to right click go to properties of the printer and do a TEST PRINT, should print out.
