Question about Hotpoint TDC32 Electric Dryer
No Heat everything seems to be working but not heating up
  • jennypete Mar 30, 2008
    same problem everything working but no heat
  • medl58 Apr 06, 2008
    The dryer tumbles ok but there is no heat. Have checked all three thermostats and they are ok (no open circuit). The heating elements seem to be ok (no open circuitĀ here as well). The Drying lamp is off and there is no voltage supplied to the heating elements. What else to check? Would appreciate any suggestions. Thanks /Magnus
Hi there, I've just been working through one of these dryers and like you found the thermostats and elements to be intact. In my case it turned out to be a faulty timer, I noticed that if I gave the timer a bit of tension in the opposite direction, sometimes I could get the drying light to flick on for a second or two, the timer appeared in good condition in every other way except that I suspect the cam has worn down (they are only nylon and possibly the heat of the contacts has allowed it to slowly erode away) something I did notice that surprised me was that this dryer draws 12 amps on high heat. I was going to strip the timer which requires drilling out the posts but opted instead to fit a separate contactor (relay) fired by one of the other pins on the timer, if you check the timer with a voltmeter you will find a pin that only works when the drum is turning in the normal direction (you don't want the elements to work when the drum is reversing) hook a wire from this to your contactor, move the element wires there as well, supply a neural from anywhere and your away. Total cost $10 for a 12 amp relay. Good Luck !!
Posted on Aug 10, 2008
    Problem Solver:
Try Float chamber behind water container (Where it snaps into), Wet lint may be clogging the micro switch hence simulating a full conatiner leading to no heat output.
Hope this helps
Posted on Jul 03, 2008
Swimrite pool heatpump not heating pool
heat pumps do not heat as fast or effectively as a direct heat system such as propane or ng. they are only effective when the outside air is very warm otherwise they will actually cool the pool water.
Jun 11, 2014 | Hayward Pool & Spa
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
Water heater doesnt heat up
has the unit every been cleand you can check the it in the service door
Dec 01, 2008 | Water Heaters
My Heater blows cold air
is this a gas furnace if so does the burner ignite
Nov 25, 2008 | Intertherm P3RA-048K Air Conditioner
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
Oct 04, 2008 | Frigidaire Dryers
Everything works but the heat! Any suggestions?
door micro switch open/need to replace / if that open the magnetron will not power no heat will produce.
Jan 02, 2008 | Whirlpool MH1150XM Convection/Microwave...
Hotpoint TDC32 Electric Dryer Logo
95 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
