Question about Samsung DynaFlat TXN2668WHF 26" TV
Feather touch screen problems "They jump by themselves"
My T.V. Monitor I bought it about 3 years ago... and the feather touch screen buttons well just one the "TV/VIDEO" Button jumps all the time without me touching it... I could be watching a movie from DVD Player and it just suddenly switches to AV1 or AV2 and it just keeps going... the feather touch screen buttons are getting on my nerves... has anybody had this problem????? PLEASE HELP THIS IS VERY ANNOYING...... !!!!!!!!!
  • Samsung Master
  • 5,568 Answers
While not familiar with this model, the effect rings a bell; it may be caused by stray static discharge.
Try this potential solution;
Use a very mild solution of dish detergent to wet a clean cloth. Ring out the cloth until it is only damp.
With the TV power off, wipe down the screen and surrounding bezel.
If the cloth is only slightly damp with the solution, you shouldn't see any smears after the solution is completely dry.
Do not follow up with an untreated cloth.
If this seems to reduce the incidence of wild switching, you might want to check with stores that sell computers or Radio Shack and procure a better antistatic agent than the detergent; note however, if the antistatic spray is intended for only cloth or hard surfaces as well.
Good luck-
Posted on Feb 25, 2008
Acer screen jumping
Check to see if the button is stuck on your monitor and remember the last thing you did before it started doing this problem.
Jan 15, 2013 | Acer Aspire Z5801 All-In-One Desktop PC...
Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
My viewsonic screen started to buzz. i bought it about a year ago. what is the problem??
well if uses a 3 prong plug to plug it in it may be a ground loop.
try this, goto a harware store and get and adapter to change a 3 prong plug to a 2 prong plug and then plug the monitor cable into that then into the wall.
diagram: power>|'.'|<power
ground
cut off the ground plug and that would also work!
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Jan 17, 2010 | ViewSonic VX900 19" LCD Monitor
Dell laptop monitor jumping
Could be your refresh rate. Try the following:
* change your monitors refresh rate to higher availible.
* rt click on desktop then on properties and then display setting and then advance and then click on monitor tab and choose the highest availible and then click ok.
Would also attempt to move the screen forward and back to see if you have a pinched cable.
Also attempt to connect to an external monitor to see if it is your laptop monitor or the video card causing the problem.
Hope this helps.
Oct 25, 2009 | Dell Vostro 1510 Laptop
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Buttons on screen jump around
Ok I have a few questions. When you mean it jumps around do you mean:
1. When you press a 3, the 3 button becomes a 7 graphically or
2. When you press a 3, the 7 button is highlighted and chosen.
The first thing I would do is try to recalibrate your touchscreen by pressing the wrench symbol, then the display icon and select calibrate screen. Press the series of dots as you are asked to do and see if that clears up your problem.
If that doesn't work, then I would do a reflash/ugrade of the firmware. Perhaps the firmware is corrupted. This can be done by dowloading Garmin's webupdater at www.garmin.com and connecting your Nuvi to your PC and letting the program reflash your firmware.
The last solution is to replace the touchscreen. Are you sure the screen is not cracked anywhere? A cracked screen will certainly cause a touchscreen to either not work or activate another button when pressed.
- Jim
SHARCNET-USA
If that doesn't
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
No menu
One of the buttons on the front of your monitor is probably stuck.
(Only one of the buttons work at a time on most monitors)
I cannot recommend taking it apart your self (have a tech do it)
But take off the front, check the buttons after you take off the front, and if it still occurs unplug the buttons from the monitor.
If it stops (which it should) replace or fix the controls)
If it doesn't, call an exorcist (just joking) or buy a new monitor.
Mar 14, 2008 | iiyama Prolite E430 17" LCD Monitor
LG 700E COLOUR CHANGES
you have touch up the solder point at the pict board. Because the solder joints dried up - lead poor contact.
Nov 29, 2007 | LG Studioworks 700S 17" CRT Monitor
LG old but brand new blank screen green light making a tik,tik,tik sound.
Nothing you can really do yourself with that. I would call manufacture and get solutions from them. When it comes to monitors, unless your skilled in repairing them you will only do more damage to them. If you really feel like jumping into it and have nothing to lose you should be able to find a service manual on this monitor here http://www.eserviceinfo.com/most_popular/list_8400.html and rip it apart to find the piece to replace.
Jul 17, 2007 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Samsung DynaFlat TXN2668WHF 26" TV Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
