Question about Compaq Armada E500 Notebook
HOW TO BOOT
AM NOT ABLE TO INSTALL WINDOWS 2000 XP OR 98 AS MY LAPTOP CD DRIVE IS NOT WORKING AM JUST TRYING TO INSTALL THROUGH BOOTABLE FLOPPY BUT SOME FILES ARE MISSING. GUIDE ME HOW TO INSTALL THROUGH FLOPPY DISK
  • Gerjoy06 Mar 06, 2008
    I have the same problem w/ my Compaq Armada E500, I wasn't able to boot it, I tried Installing again the Win98 but it has a message "NTDLR missing. What should I do to fix this problem?
    Thank you very much!
  • brian c
    brian c May 11, 2010
    What do you mean "not working"? Is the drive itself faulty, or is it just not recognizing it?
  • 35 Answers
If you have access to an external drive enclosure, OR you have a computer you can put the hard-drive from
that machine in temporarily, put the drive in one of them and copy the WIN98 directory to the harddrive.
Once the WIN98 directory is there, you can just install it from there. That is of course if the hard-drive has been
formatted with the /sys command, and set to primary boot drive using FDISK. As far as installing from floppy,..
the floppies haven't been on the market for a LONG time, and if you have them,.. I imagine they've seen better
days. If you HAVE to install from floppy though, use another computer, put in the CD, open the cd using windows
explorer. Once here, click on the WIN98 directory, and locate the files you need ( too many files and directories
to list here ) Seriously the best way would be to use an external drive enclosure ( since it's probably a 2.5" drive
size ) and just copy the whole directory to the drive and forget the floppy idea. It will take MUCH less time.
Posted on Feb 25, 2008
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
Sep 24, 2012 | Computers & Internet
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
Cannot boot up from CD-Rom with Win 95 and Win 98
You probably have a version of windows 98 that was not bootable on CD. You would need to boot from a windows 98 floppy bootup disc, then go the the d:\win98 directory and run setup from there.
May 26, 2009 | Intel Computers & Internet
Can not install windows 98 on my gateway solo 9300
ok first your gona wana disable that ios password cuz wat that does is it locks some stuff up tht are critical to the system and then go in to your boot seequence and selct first boot device as floppy then 2 cd 3 hard drive and screw the rest then it should work
May 24, 2009 | Gateway Solo 9300 Notebook
Boot cd problems
You can't just put the windows cd in your cd rom drive. If your going to change your boot order (to cd), then you HAVE TO use a BOOTABLE cd. That means a bootup disk with all the correct bootable files for WINXP. Same with a floppy. Change your boot order to a floppy....and in order to bootup windows, you MUST HAVE the bootable files ON THE floppy. In your case...the cd. The windows xp does not have the bootable files since it is only used for install and reinstall.
Create a bootable CD or floppy (((from someone elses WINXP pc or laptop))). There is a feature that allows you to do that. Then when you boot to cd it will start windows and give you options.
Mar 31, 2009 | Panasonic Toughbook CF-27 Notebook
Formatting IBM Thinkpad 600E
I know you can't boot from the Windows 98 CD, and probably not from Windows 2000 either. It is possible to turn the the Windows 98 bootable floppy into a bootable CD, but I think you would be much better of trying to install Linux.
Mar 16, 2009 | IBM ThinkPad 600E 2645 Notebook
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
NOT booting WINDOW XP
Hey stanley154
try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
all the best
zinja
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Compaq Armada E500 Notebook Logo
198 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
