Question about Mitsubishi WS-65511 65" Rear Projection Television
TV won't turn on
So i'm having a problem with my TV. It won't turn on. It's plugged into the wall outlet. Also in the wall outlet is a surge protector with various devices plugged into that which all work perfectly. Things such as a DVD player and a radio. The TV used to turn on fine before with the surge protector and it's devices so i'm thinking it has nothing to do with that. Anyways, when I push the power button on the television, nothing happens. I've pressed the reset button and the power light blinks for about 25 seconds or so before stopping. After I would push the power button again. I've tried holding the power button in for 10 seconds and the reset button for 10 seconds but nothing happens. Still the TV won't turn on. I don't have the manual for the television so using that is not an option. If anyone has any suggestions as to what I should try or do, I would be very grateful. Also, I've had the TV for roughly 5 years or more. t.v will not turn on someone told me that a part called pwb sbm #935D5840 2 is problem is that possiable if so were do i get part mitsubishi will not sell it to me
  • 2 more comments
  • Anonymous Feb 27, 2008
    I can turn the tv on for about 3 seconds and then it turns off. All of the other electronics that are plugged in work. Receiver, dvr, vcr tec. We get the green power light on then shuts off after exactly 3 seconds. Is there an internal fuse that needs to be replaced?? We've unplugged and plugged everything back in so we know it must be something internal. Please help!! Thank you.
    G. Reese
  • snoozey13 Aug 10, 2008
    I have the same tv (Mitsubishi 65511) and the same problem, (won't turn on). The manual says to hit the system reset. When the flashing stops, then try to turn on set. That didn't work either... I tried the solution of hitting both the device and menu buttons to come up with a troubleshooting code, but that didn't help either. Are there any other solutions?
  • bille11 Sep 11, 2008
    I have the same TV. 3 days ago it stopped turning on. The green ligt comes on for approximately 2 seconds and then turns back off. I've tried the reset but no success. Any suggestions would be appreciated.
  • IM4OU Sep 23, 2008
    I have the same television and the same problem. My power indicator, green light, blinks for about 45-50 seconds and then goes off. I tried to turn the power switch on and nothing happens, no relay clicking sound or anything. I held the menu and device buttons in for over 10 seconds and it has no effect.
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 25, 2008
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
Does not turn on, light flashes, it clicks once, the remote control will not even turn the light on
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Jan 21, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
Attempt to turn on the television.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
Sony Grand WEGA KF42WE610 42" turns on and off
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Surge protector shuts off while playing PS3
swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
