Question about Dell 1600n All-In-One Laser Printer
Problem with scanner not feeding pages to scan
Problem with scanner not feeding pages threw machine to scan the pages
  • Cameron Scott May 11, 2010
    Open door of paper feeder (located on top of scanner) and try to see if any obstacles are present. Go ahead and press "Copy" with the feeder door open. Do the pages feed all the way through? Obviously with the feeder curved door open, they will not feed into the scanner bed, but you want to make sure they at least feed out of the tray and into the feeder completely.
    Let me know your results.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
I'm assuming these are completed?
Posted on Aug 19, 2008
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
9080c fails to scan single page; has trouble scanning a batch.
Hi
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
Feeding problem
There are quite a few optical paper sensors in any scanner. If one of them is blocked by a shred of paper, the scanners 'assumes' the paper is available and starts scanning. Try to blow air and clean the scanner. Take care not to damage the sensors. S. Mohan, India
Dec 24, 2008 | Canon DR 2080C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
Scanner take a minute a page using form feed.
Yes, there is something you can do..... Get a bigger and faster copier.. There is not much you can do.... It is slow..... Sorry, can not help you with that.
Apr 23, 2008 | Sharp AL-1642CS Copier
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Scanner excludes front page
This is not the only solution, but this might help.
Put a blank page in as the first page and see if all of your documents scan completely.
You may need to clean the ADF. Try the following:
Cleaning the Automatic Document Feeder
You may need to clean the ADF feed mechanism if your
documents do not feed easily into the ADF, or several feed in at the
same time.
To clean the ADF:
1. Dampen a soft cloth with some isopropyl rubbing alcohol
(95%).
2. Press the ADF cover release on the top left of the scanner body
to open the Automatic Document Feeder cover.
3. Wipe the feed roller from side to side. Rotate the roller to clean
its entire surface.
4. Wipe the pad from top to bottom. Be careful not to snag the
cloth on the springs on either side of the pad.
5. Close the cover when you’re finished.
NOTE: Please be careful when cleaning the roller. The roller is
designed to rotate in one direction only. As you’re cleaning the
roller, make sure it rotates easily, and continue rotating it in that
direction while wiping it clean. Do NOT force the roller to rotate
in the opposite direction. Forcing the roller to rotate will damage
it, and may cause the scanner to feed pages incorrectly.
Please let me know if this has helped and thank you. Binary Bob
Dec 05, 2007 | Xerox DocuMate 252 Path-Through Scanner
Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Nov 20, 2007 | Canon DR-3080CII Path-Through Flatbed...
Dell 1600n All-In-One Laser Printer Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
