Question about Brother MFC-8220 Fax
I need installation software..
I've been having problems installing the machine to the computer..I do not have an installation disk
  • 108 Answers
I had microsoft publisher 98 installed on my computer but the system crashed so I need to reinstall. Problem is that I purchased the software years ago and still use it to make newsletters, cards, etc....
It is not possible to install it without the auth code. You can contact microsfot and they can provide you with an auth code you can proceeed with.
Apr 05, 2013 | Microsoft Publisher
NEW MacBookPro crashes! I just bought a new macbookPro and it has crashed on three different programs; won't download the manual from online (get the beach ball) and makes a sound when power-ing u
The two "whirring" noises that you hear on power up is normal. The beauty of having a new macbook is you can reinstall the software very easily and a fresh install should fix your problem. Put the disk that came with the machine into the disk drive and turn the computer off. Turn it back on and press and HOLD the "alt" button until you are given the option of booting from your hard drive or your disk. Choose the disk and when it boots up, FIRST go to disk utility and verify the hard drive. If it comes back with no problems, proceed with the fresh install of the system by following the prompts on the disk.
Jul 07, 2012 | Apple Computers & Internet
Hi. I've just purchased a computer but without the harddrive. I do have the o/s key but I'm not sure how to install the system without disks. Any help would be greatly appreciated!
You have to borrow or buy the install disks (Not the recovery disks), the problem is that not all keys work with all copies of the system.
Jun 04, 2012 | HP Computers & Internet
I have a Netgear Wireless N150 router. It has been installed on our 2 computers. However, I had to reinstall Windows Vista on one and when I tried to reinstall the router, it tells me "No working...
Sounds like the driver for the network adapter has not be installed following the re-install of vista
to verify
go to start-->control panel-->System
Click on 'Device Manager'
Look for any devices that have a question mark or exclamation mark next to them
I suspect you will find something like 'Ethernet controller' which wont be configured correctly.
You will probably need to download the driver, using your other machine and then transfer to the problem machine and update the driver
If you need help identifying the driver then please provide details of the make/model of your PC.
If this doesn't solve the problem then let me know before rating this answer and I'll try to help you further
Good luck
Sep 06, 2011 | Computers & Internet
I purchased some software to monitor calls on my daughters cellphone. the software was sent to me and i need to save it to my computer and then download it to my HTC thunderbolt phone. how do i do this?
The software installation file you have purchased is in "APK" format which is what Android will recognize as an application installer.
To install applications outside of the Market you must select/check "Unknown sources" which is located under "Applications" which is located under "Settings."
1. Connect the HTC Evo to your computer via it's USB cable.
2. Select mode of connection as "Disk Drive" (a menu with these options will pop up after connecting through USB).
After that is done, your computer will now recognize your HTC Evo as a Disk Drive.
3. Go to the location of the file you've download and want to transfer to you daughter's Evo- Select it, hold down "Ctrl" key while pressing the letter "c" (to copy the file).
4. Go to the location of the HTC Evo now known to your computer as a "Disk Drive" then hold down "Ctrl" key while pressing the letter "v" (to paste what you've copied).
Now that the file is on your daughter's Evo you simply need to:
1. Change the Evo's mode of connection from "Disk Drive" to "Charge Only" or just disconnect the USB cable.
2. Browse to the phone's app directory to start a file manager application (download one from the Market if you don't already have one- I recommend "ASTRO File Manager").
3. Navigate (using the file manager) to the file you've transferred to the phone and just launch it. The next prompt will ask if you want to install the application- select "Install."
Done.
Aug 13, 2011 | HTC EVO 4G Smartphone
Hi mate i have a wd passport hd, and i took it out when my computer wa restarting. and now my computer and any other computer dont read it it say reformat. it has very importent files on how can i retrive...
Here is a 10 day free trial of a software recovery program that can be burned to a disk. You would then boot from that disk with your external drive plugged in, and after it loads the software, tell it to find all available files. When you find your files, copy them to your regular hard drive and reformat the external. Copy the files back to your external drive. Hope that helps some.
http://www.ntfs.com/products.htm
May 03, 2011 | Western Digital Passport 320GB External...
I have recently bought a new computer and i installed the software, but the machine will not recognise the computer, can it be installed on computer with the new windows 7 or do i need an update??
Yes, it can be installed on Windows 7. Check the Futura support sight at www.Futura-support.com and look on the right hand side under downloads. There's a download listed for CE150/250/350, etc, that applies to XP 32 & 64 bit, Vista and Windows 7 32 & 64 bit. Follow the directions CAREFULLY! If this doesn't work for you, I've posted a set of instructions under CE100 solutions for running the CE100 software on Windows Vista/7 by installing a Virtual Machine software on Windows 7 that works regardless of the situation.
The update should work for you perfectly, however. Just make sure you uninstall the Futura software and reboot your machine BEFORE you do anything else and follow the instructions from the website carefully! Good luck!
Jul 29, 2010 | Singer CE350
Software work to slow and it shot down
Software Installation : Installing more and more software can make the computer slow down. The reasons for that are that installation of a software will make entries in registry and that is somewhat bad. The software may be running in the startup. The software will install various files on the computer and an overloaded hard disk makes the computer slow.
Free up disk space : Try to keep your hard disk space free. You’ll always notice that a computer with free space on hard disk will always run much faster than the one which is loaded with extra stuff.
* Remove Unwanted Items From Startup : Well, if you’ll remove the unwanted softwares from the startup then your computer will boot up much faster and the memory (RAM) will also remain free and thus that will again result in better computing experience
Run hard disk maintenance utilities : Always run the utilities like Disk Defragmentation or Disk checking utilities regularly, around once in 2 weeks
Run Registry Cleaner : Right, this one is related to first tip. In case you’ve already installed and uninstalled various softwares before reading this tutorial then you can go ahead and run various registry cleaning softwares
Oct 14, 2009 | Computers & Internet
When I tried to load the software for my Singer CE 150 i got this message: Futura Software is not installed in your computer. Install the application and repeat the setup. I have windows xp. I have...
Run a disk cleaner through it and clean the disket with a dry soft cloth. After awhile the disk drive will get dirty and it cant read a disk.Do this once a month and you should not have anymore problems. Go to your local dollar store and pick one up.
May 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Brother MFC-8220 Fax Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
