Question about Bakers Pride BAK-DS805 Gas Single Oven
Bakers Pride Y600 - Bottom Burning Pizza's
New Bakers pride oven having problems with Pizza's burning on the bottom.
Have tried diffrent vent positions and temps.
Works best when all vents are open and oven is set at 550 degrees.
Door is always shut.
  • 3 more comments
  • Anonymous Apr 06, 2008
    I have the same exact problem for about 5 yrs..Old bakers pride oven exactly the same did not have this problem..Bakers Pride says they will look into it..they will not admit there is a problem
  • giaimo May 07, 2008
    my pizza burns too on my y-600 everything will be fine and out of nowhere it just gets stuck to the stones and smells like burnt toast
  • Anonymous Jun 16, 2008
    bp 600.. just starteed burning pizza on the bottom
  • Anonymous Sep 16, 2008
    it is your bricks these bricks that bakers pride are using do not retain the heat so the heat goes right through which will burn the bottom of the pizza you must change the bricks to to old stlye which is hard to find i am in the pizza oven service biz and i do have those bricks once you change the stones your problem is solved GAURANTEED BY CARBO OVEN SERVICE 718 288 4336 ASK FOR RON THE OWNER
  • aamortgage May 14, 2009
    I have a 251 oven and find that the base of the pizza is always burning. I have tried different variations, but cannot solve!
  • 142 Answers
SOURCE: bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Posted on Apr 22, 2008
SOURCE: Door on my bakers pride y600 pizza oven
i have the same ovens and you only get the bushings ac far as i know when you buy the door spring assembly .make sure you get the right one because there are 2 sizes ,the older ovens have a thicker bushing.and its not that hard to replace if you can take it apart.that door is very heavy so be careful
Posted on May 08, 2008
r carbo
  • 21 Answers
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
Posted on Nov 25, 2008
  • 125 Answers
SOURCE: thermostat setting for bakers pride y600 oven.
Hi, those screws are for the calibration of the knob to the thermostat, so your calibration is correct. Most likely you will have to contact a servicer to check the calibration, and set you knob and plate where they will align with the actual temp again.
Hope that helps, and thank you.
Posted on Jan 05, 2009
  • 3600 Answers
SOURCE: bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Posted on Jul 22, 2009
Stones get too hot, burns on bottom before top cooks
Assuming you have the oven adjusted properly maybe the thermostat might need to be replaced?
I would try and adjust the flame to a lower height before replacing the stat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 23, 2010 | Bakers Pride Y-600 Gas Single Oven
I need to get 2 slates for y600 pizza ovens do you sale them.
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps
Apr 15, 2010 | Bakers Pride P-44S Oven
One of our ovens has part of the bottom pealing off inside the oven. Is there a fix for this?
Unplug the unit, remove the conveyor belt and replace the bottom of the oven with a Stainless Plate from Bakers Pride or from a local machine shop
Nov 30, 2009 | Bakers Pride APC-18-1 Electric Single Oven
Bottom oven pilot light goes out intermitantly.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Pilot, controler and gas knob needed replacement
If you have the older Bakers pride manufactured more then 20 years ago and it has never had service, it sounds like the safety valve is defective, that's the red button you push in the light pilot, if the pilot is lit and when you turn the manual gas valve on for the main burner to lite and still it does not you problem still may be the safety and/or a failing thermocouple.
Apr 02, 2017 | Bakers Pride CO11-G2 Gas Double Oven
Thermostat setting for bakers pride y600 oven.
May 19, 2008 | Bakers Pride Y-600 Gas Single Oven
Jan 20, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Bakers Pride BAK-DS805 Gas Single Oven Logo
528 people viewed this question
Top Bakers Pride Ovens Experts
Craig Butler
Craig Butler
Laxman Bisht
Laxman Bisht
Paul Carew
Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
