Question about Palm Tungsten T3 Handheld
Battery replacement Followed directions as to taking apart, all went well. But can't see how the little white end of the battery fits back on motherboard. Just pried it off with directions, but fitting it back on is a challenge. Is there an easy way? thanks
    Problem Solver:
  • 36 Answers
What directions have you been following. On pdaparts.com they have both guides and videos. They may help you. In the column on the left of the home page, second section (section labeled "Company Info" :) fourth item down is "Repair Directions". You can find take-apart guide and video for the T3 on that page.
Posted on Mar 05, 2008
Shark Stick Navigator won't turn on.
Call cust. service. They send you a new machine,
Jan 18, 2014 | Shark Navigator Freestyle Stick Vacuum -...
I threw my dish remote against the wall and a small white piece of plastic jumped out after falling apart? how do i fix it?
If you have a IR/UHF remote then the littel white peice go to the switch that tells the remote to send UHF or IR signals. This little white peice will fit on the end or the green board at teh very bottom of the remote, it will slide into place allowing the colored tab to move it back and forth to enable and disable UHF and IR frequencies. These remotes are built very tough, i would say you threw it pretty hard lol. You may need a replacment if you continue to have issues.
Dec 06, 2009 | DISH Network IR Remote Control
Car won't start and dash light flickers
Sounds like bad connection at battery. Remove the battery connections, clean the battery posts with a wire brush, and reconnect battery. Make sure connections are tight.
Jun 03, 2009 | 1999 Acura TL
Canon ixus 50 screen went into phsycadelic pattern purple black and white. Now screen is black. Lens moves out a little and only retracts fully with assistance. Battery is fully charged.
take it apart ie take the battery out, the memory card out and put it back together putting the battery back in last and try and turn it back on, if that does not help then I would get in touch with Canon and see if you can swap it or get it repaired via warranty if its still under warranty.
If you have had it less then 3 months you may be able to take it back to the shop where you got it from ( whether its online or physically at a store ) and see if you can get a replacement.
Apr 10, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Screen turned white
Remove the back cover, Remove the battery, if the phone is GSM take the little card out of the back of phone by sliding the metal cover in proper direction. Should be arrows. Put the Sim card back in battery back in then turn phone on. If this doesn't work let me know. Main thing is reseating the sim card. (this assuming you a service provider that requires a sim card. )
Jan 01, 2009 | RIM BlackBerry Pearl 8100
Taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Garmin Forerunner 50 Battery Replacement
Thanks MarcS_Ca - I've supplemented what you offer with some photographs at
http://gnjmch.com/public/tips/GarminF50.Battery.html
Aug 30, 2008 | Garmin Forerunner 50
Calibration strip location
I got my answer from a very helpful scanner expert from a posting on the newsgroup comp.periphs.scanners. The plastic piece went near the end of the bezel that holds the glass above the starting position for the scanning run. Once I knew the idea, locating where it went was easy because of small indentations in the bezel the shape and size of the plastic piece. Thanks.
Aug 07, 2008 | HP Officejet 5610 All-In-One InkJet...
How to replace the elboe on the power nozzle
wouldnt recommenddoing it urself as it may have warranty. But if u have the head off and the elbow apart im not sure what parts u have. If u have both these taken apart. It is pretty much self explanitory. u need to take the prongs out of the one end. At the other end ot the wires there r two attachements. The end that is at an angle attaches to the reset button which is by the L shaped part. The opther wire attaches either directly to the small motor itself, or to another wire which has a plastic cover on it. The wires that you took the prongs off of the rest along side the little knobby piece and then you wrap them around the middle of the knobby piece. Slide the elbow sleeve over the knobby piece and then turn it so u can bring the ends of the wires out of the little hole in the middle of the elbow sleeve. When the is done attach the two little clips back on the the elbow the one on the inside and the one on the outside at the back of the elbow. reattach the prongs to the ends of the wires put them into the notches about the middle of the elbow sleeve. Reattach the little cover and ur done. If u have the whole assembly. Take p/n cover apart and reattach wires where they r already connected inside the head. Put the head back together. Feel free to give me a call 1-866-966-9350.
Jul 13, 2008 | Electrolux Guardian Bagged Canister Vacuum
Replacement Battery
I have the same issue as well, I went to Batteries Plus and sized up some batteries, the closest one was a replacement for an IQUE 3600 PDA, Batteries Plus # PDA-35LI. 3.7 volt, 900MA. $39.99 you'll loose a little bit of the "new in the box" runtime however probably not much Its just a MM or two wider, however its slightly thinner AND it already has the right connector on it. The fit is almost perfect. Being wider it kinda hits the wires that go to the output pin connector however with one thick layers of double sided tape it clears them perfectly and being thinner there was no clearance issue getting it back together. Be careful if and when you take your unit apart, the flip up antenna has a spring loaded pin on the right side that can pop out, mine sprung out and not knowing what to look for it took some time to find it. There is a small silver spring and a black oval shaped pin. Its working perfectly now!
Apr 27, 2008 | Garmin Quest GPS Receiver
Palm Tungsten T3 Handheld Logo
115 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
