Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice maker not working
My Hotpoint side by side ice maker is not working. Water will dispense when the bottom is pushed, but if you try to dispense crushed or cubed ice nothing comes out. The ice maker is not even making any ice to be dropped down into the ice bucket.
ice maker not making ice,changed the filter. green light blinking, i turned it off
cleared the old ice from the maker.restarted,still does not work
  • 5 more comments
  • Anonymous Mar 23, 2008
    Icemaker does not make ice.
  • Anonymous Mar 30, 2008
    If I have purified water supply, can I by pass the filter and the purifier? Will water flow by gravity and can ice cubes be made that way?
  • Anonymous Apr 22, 2008
    Motor not turning depsencer screw when lever is pressed on front of door.Reset on-off switch on icemaker,removed ice tray and made sure despencer scew turned freely.Is there anyway to test the motor/door lever?
  • Nannyof8 May 04, 2008
    Get cool water out of cold water but big problem is ice maker quit working. Solenoid good so it must be in the freezer mechanism.
  • Anonymous May 29, 2008
    I'm having the exact same problem with mine!
  • Mimi44 Jun 25, 2008
    Same problem: Ice is not coming through the "ice despenser"...I held the button in (thinking it might be stuck)..but just got a "motor burning" smell. Panic!!!!!
    Any ideas what I can do to fix this problem?
  • Anonymous Jun 28, 2008
    I can't get mine to make ice. Sounds like machine is working. Water works.
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 520 Answers
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Posted on Jun 28, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
  • 4070 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
Ice dispenser not dispensing ice or water
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Jun 24, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint Side by Side leak and cooling issue
fault is poss that drain for defrost water is blocked and this can cause both faults. remove back cover of freezer and check if ice build up. if so melt of with hairdryer and make sure drain is also free of ice
Feb 15, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
433 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
