No Beep, No LED Read-out just - -
This began over the Thanksgiving holidays, 07. My computer would not boot to the BIOS. After stripping everything down to only the CPU and mobo, I assumed it was the mobo. I sent it back and it was found faulty. After I got a replacement board, it did the same thing. I sent back the CPU and it was found faulty as well. After I got a replacement CPU, it did the same thing. I went and bought a new PSU and it did the same thing.
I now have another RMA with the mobo supplier, but they swear they tested the replacement board before it went out. So, before I send this board back, I thought I'd get some advice here. Below are my specs.
Mobo: Nvidia 590 AM2, SLI, MCP, ATX, AMD
CPU: AMD Athlon 64 X2 6000+ Windsor 3.0 Ghz, Socket AM2
PSU: Rosewill RP 550V2-S-SL, SLI ready
MEM: Corsair XMS2, DDR2 800, PC 6400, 1GB x4
Thanks
  • 3 more comments
  • Pythium Feb 25, 2008
    No. The computer will not work at all and can not even get to the BIOS. And, I've reset the CMOS and removed/reinserted the battery.
    Yeah, this problem has perplexed every computer repair shop within a 50 mile radius. They also can't test the board being it's a 4+4 pin ATX. However, I've heard that mobo's are sometimes sent around on a continuous cycle (Conspiracy Theory). But the supplier insisted that it was tested before it went out. I've finally talked to a traveling computer repairman and I hope to hook up with him in the next couple of days to see if he can test the mobo and CPU. I really want to get this info before I send the mobo back and look like an idiot :). Thanks for the reply!
    When on the phone with the mobo supplier, they had me take it out of the case for the very same reason. Since then, i've left it out of the case to continue to run tests. The only thing I haven't tried is different/ new RAM. However, for 4 sticks to go bad at once would be extremely rare and I would think if the RAM was bad I'd get some kinda of POST error code or beep. I get neither.
    Tks again.
    Haven't tried the VOM yet, but I ruled out the PSU when I tried a new one. Yes, all fans and lights on the mobo coming on but - - on the LED and no beeps. I may try a VOM (assuming you're meaning Voltage Meter) tonight. I guess either the mobo manual or PSU manual would list the correct voltages i should receive.
    Oh..and yes. I've tried all configurations possible with the RAM. With all the reading i've done, on this board and others, it's got to be the mobo, if not the CPU. The main reason I'm ruling the CPU out is of these (3) things.
    1. The new CPU came in a retail package. It looks and smells new.
    2. The mobo came packaged as an OEM part. Yes it may be new, but it didn't make me feel all warm a fuzzy like the CPU did.
    3. They are no longer making the 590 board. Suspicions arise with that as well.
  • Pythium Mar 12, 2008
    Update...The 2nd mobo was bad too. The customer support rep. said that the 2nd board was good when it left their shop; true and tested, and that it must be either something I'm doing or one of my hardware components is destroying the board. I had my PSU tested and it was ok, so what the heck are they saying. The only other conclusions I could think of were:
    1. The CPU was bad too; therefore it did something to the board.
    2. The RAM is bad, therefore it damaged the board. (mentioned by their customer support)
    3. Static electricity?
    Granted, these are far fetched conclusions, but I don't want to damage the next board they send me if it is.
    Sergeant:
  • 324 Answers
Sounds like you have pretty much covered about everything. Are you saying that the system works OK, except when you try to get to BIOS, or is it not working at all?
If you are just having trouble getting into BIOS, there is the possibility that something is wrong with the F key that you use to access BIOS. Might try a different keyboard if this is the case.
I know that this is kind of a stretch, but haven't been able to think of anything else, yet.
Ron-
Posted on Feb 25, 2008
  • 1 more comment
  • Ron Roske Feb 25, 2008
    Strange one, huh?
    Did have one other thought. Is there any chance that the MoBoard might be shorting out on a screw or on the case? Have had this happen to me due to improper reassembly and/or missing insulation on bottom of the board.
    Another possibility is a bent pin on CPU, but assume you have checked for that.
    With only the PSU, CPU & board installed, it should do something at least.
    Ron-
    Agreed that one wouldn't think that 4 sticks would go bad at the same time. Have you tried bringing it up with only 1 stick of memory? Then try to bring it up with a different stick? Is it safe to presume that the fan(s) come on when it is powered up? Have you been able to use a VOM to check the voltages from the PSU to the board to verify that they are there and correct?
    Any lights or LEDs coming on?
    I know that these suggestions are pretty basic, but we're starting to run short out of ideas.
    Ron-
    Sorry 'bout that! Yes, VOM means volt ohm meter. And, yes, the manuals for either (or both) should give you the numbers.
    Ron-
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
Display problem, CPU Fan starts but no Power on self test begin. Pls help
The computer power-on self-test (POST) tests the computer to make sure it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem. Once the problem is located, simply replace the defective part.
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep CodeDescriptions1 shortDRAM refresh failure2 shortParity circuit failure3 shortBase 64K RAM failure4 shortSystem timer failure5 shortProcess failure6 shortKeyboard controller Gate A20 error7 shortVirtual mode exception error8 shortDisplay memory Read/Write test failure9 shortROM BIOS checksum failure10 shortCMOS shutdown Read/Write error11 shortCache Memory error1 long, 3 shortConventional/Extended memory failure1 long, 8 shortDisplay/Retrace test failed
Jul 27, 2011 | Gigabyte Computers & Internet
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Power won't turn off and computer will not boot. I've removed the battery and cleared the CMOS with the jumper. lt happened after a couple of power failures at home however pwer supply has a surge...
If i understand you correctly, you are saying that you have a single beep repeating over and over with nothing showing on the monitor and no other response from your computer? The single long beep in a loop is an Award Bios beep code for a faulty CPU. This problem is not mentioned on the official website of the manufacturer. Unfortunately your only option is to replace the CPU. You might try removing and re-seating the cpu making sure you have proper cooling measures in place. Hope that helps!
Dec 11, 2008 | Biostar M7VIZ Motherboard
No boot up, display, beep, or HD action
I am having the same issue. Clearing/reset the bios will get the board to boot up, but when turned off and started again the board will not boot. you will have to clear the bios again. The board seems to be rebooting itself continuously before it evens get to the POST.
Jun 28, 2008 | EliteGroup P4M800PRO-M Motherboard
PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Dec 15, 2007 | HP Compaq dc5100 PC Desktop
Princeton VL1715 startup problem
Have you disabled your onboard video in the BIOS? Boot your machine with the vga cord to the motherboard. You need to get into the BIOS. Depending on the make of your machine you need you will need to hit the del key, f2, or even f1. Go to the periphrial setup and disable your onboard video. Save the BIOS turnoff the computer and plug the monitor into you vga card. That should do it. To change it back to your motherboards vga just reverse the instructions. Let me know what happens. Good Luck, Tim
Feb 15, 2007 | Princeton Digital VL17151 17" Flat Panel...
Computers & Internet Logo
244 people viewed this question
David Payne
David Payne
