Question about Microsoft Windows XP Professional
I cant open drive on double click
When i click on c or d drive it not open or not explore can u help me
I had this problem too, then I made a new topic here and guys like Ravi and Manmeent helped me out her's what Ravi wrote (only instead of C write E and F):
go to command prompt and write this command
c:\> attrib -r -s -h autorun.inf
c:\> del autorun.inf
d:\> attrib -r -s -h autorun.inf
d:\> del autorun.inf
restart the pc
And here's the best and easyest suggestion .
1Open Start >> Run and type regsvr32 /i shell32.dll
2. press ok
3. You will see a message DllRegisterServer and DllInstall in shell32.dll succeeded
4. that�s it
SFE and tol PLEASE write how you solved this problem!
Posted on Nov 13, 2008
  • 108 Answers
Right Click on the Drive Icon and select Explore or Open. You can open the Hard Drive.
But now an Alert for you.
If you are seeing the other option than Open in bold letter then your PC is seriously infected with Virus, Run a good and updated Antivirus.
Posted on Feb 25, 2008
Why i cant open internet explorer
When you click the Internet Explorer icon, window may flash a second and quits. Or, it may show an Error-Reporting dialog. This may be due to a malware Browser Helper Object which causes Internet Explorer process to terminate. If you see the Error-Reporting dialog, click "to see what data this report contains" and identify the Module Name causing this error. In most cases, it may be the malware DLL; in which case, reinstalling Internet Explorer may not help.
1. Click Start, point to Settings, and then click Control Panel.
2. Double-click Internet Options.
3. Click the Advanced tab.
4. Under Browsing, clear the Enable third-party browser extensions (requires restart) check box.
5. Restart Internet Explorer.
Download Ad-Aware from and follow this:
1. Start Ad-Aware.
2. Click "Check for Updates", "Connect" and download the latest pattern file if available. and click Finish
3. Click "Start", "Next"
4. After the scan is finished, click "Next"
5. Select all the items (checkboxes)
Right click on any object in the "Scan result" list and choose [Select all objects]
6. Click Next and click OK to confirm removal.
Jun 23, 2011 | Computers & Internet
Drive not open on 'double-click'
Open 'Notepad' and write following code.
Save file as 'autorun.inf'.
Copy/replace this file on all drives/partitions that are not opening on double-click.
Restart PC and now all drives should open with normal double-click.
on Aug 26, 2010 | Computers & Internet
How I can open this external hard drive
1. Connect the drive to your computer
2. Go to My Computer
3. Double-click the external drive (it should be listed under "Devices with Removable Storage")
4. Explore and use your hard drive
2. Double-click the external drive (it should be on your desktop)
3. Explore and use your hard drive
Hope this helps!
Mar 19, 2011 | Hitachi Computers & Internet
I cant get my ASUS to let me view my external hard drive. How do get it to open it up?
Usually one simply double click's it, or right click and choose "Explore"
Jan 27, 2010 | Computers & Internet
Flash drive does not open when clicked on, but 'explore' works
Useualy when it says it cant be stoped its because some program is useing it, if doubble clicking on the drive in "My Computer" doesn't work its because there is a corruped file in the auto play, no real need for panic, cuz it will open if used under "exsplore" try another flash drive and see if it does the same thing to see if its just the drive or your PC. Ill bet it's just the drive. GL Hope this helps.
Jun 20, 2009 | Western Digital 500GB My Book World...
Changing how to open drives
2 things...go into ur Control panel and in the MOUSE area change the way ur mouse clicks to run things..then save those settings.
OPen Real Player options or preferences. Look for an option to how it handles running things. then uncheck it. save those settings.
May 24, 2009 | Microsoft Windows XP Home Edition
Kingston 2GB pen drive not opening by double click
This is cause by a virus or something , first thing that you can do here is to back up all the files from your pen drive and then one everything is already back up you can go ahead and format the drive, just right click the pen drive and select format....that should;d fix the problem,,,,
Dec 28, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini).
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
May 31, 2008 | Microsoft Windows XP Professional With...
Cannot open my D drive by double clicking but it shows the option open with note pad help
You drive has been infected by a virus. but I think you can still open it by not double click rather to right click on the D drive and choose explore from the menu.
But this not the solution save the files somewhere and work out on removing the virus.
Mar 27, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
