Question about Electronics - Others
Generic usb device mp3 player
I got generic usb device mp3 player, i encrypted this player and partition my 2GB device then drop to 45MB this is the firmware version
LSD_501_10
SDK:V35.37
2006-09-10
Pls help so as to fix it.
CONTACT ME
ken4real_4luv@excite.com
  • arun-india Aug 26, 2008
    i got generic usb device mp3 player, i encrypted this player and partition my 2GB device then drop to 1gb.
    LSD_501_10
    SDK:V35.37
    2006-09-10
    I got everything which can help me to repair it but not above mention Firmware..just give me the link of it where i can i download it....
    Top Expert:
  • 47,754 Answers
Sorry but we do not have that information here but mp3 players are not made to be encrypted. YOU MESSED UP
Posted on Dec 07, 2017
4 Suggested Answers
SOURCE: MicroSD wont work in MP3 player
mp3 player wont recognize videos....jus mp4 will do it if the video is in mp4 format
Posted on Sep 23, 2008
pankaj_dic
  • 1250 Answers
SOURCE: firmware
go to the manufacturer's site, and check for the support there
Posted on Nov 28, 2008
acdr
  • 1913 Answers
SOURCE: firmware problem
firsr press power button for 10 second.then remove battery and memory card.then check if is still dead the try thids link
http://www.s1mp3.org/en/docs_deadrec.php
My mp3 is all ******** u know,whenever i put songs in it,FORMAT ERROR occurs when i play it,dont know what is ******* it up.if anyone can fix this problem please help.thanks.
if You are experiencing "Format Error" messages when adding or accessing music/videos on your player. this could be as a result of a corrupt memory region or not having the required or supposed memory size of the player(actual memory)
what you do you should format:
formating Ensures that what you have bought, is of the actual memory capacity.
. 1. You will not lose any firmware/theme related files.
2. You will not accidentally kill your player whilst doing so (unless you unplug or disconnect your player during the format process).
follow the step below to guide you
STEP 1
Back Up All Your Data Before Proceeding! This Guide Will Clear Everything In Your Player's Memory Chip!
Install MP3 Utilities, any version will do. It usually comes on the CD with the player, or you can download version 3.68
Here, or version 4.03 Here, or version 4.05 Here. Any one of these will do. The Disk Tool Utility is the same.
STEP 2
Start up MP3 Utilities Disk Tool.
You will be shown a screen like this:
Ensure that you select LOW Format Type.
Next, go to the Partition and Encrypt tab as shown below.
Now, slide the Partition Slider all the way to the Right.
You will notice the "Setting encrypted disk capacity" increases, it is normal.IMPORTANT.IF YOUR MP4 PLAYER IS LIKE 2GB OR MORE MAKE SURE THE PARTITION AND ENCRYPT TAB WHEN YOU INCREASE IT SAYS YOUR PLAYERS MEMORY.FOR EXAMPLE.IF YOU HAVE A 4GB MP4 PLAYER AND YOU ARE SLIDING THE PARTITION AND ENCRYPT TAB MAKE SURE THAT WHEN THE NUMBER INCREASES IT SAYS SOMETHING LIKE 4000MB.IF IT DOESN'T DO THIS DO NOT REPEAT DO NOT DO THIS ENTIRE PROCESS.
*NOTE* Ensure That You Do Not Click The "Set Username And Password", Leave It UNTICKED.
Next, click on Start to begin the format and partition process. You will be presented with a dialog box like below, click on Yes to proceed.
It will take a few moments for the process to complete. You will notice that your player would disconnect from the computer, and then re-connect back again.
You will be presented with the "Complete setting disk partition!" dialog box like below.
STEP 3
Go to My Computer and check that now you will two memory drives for your player. You might need to click Refresh or press F5.
One of which would be small (about 17MB), and the other would be the remaining memory capacity.
Do not worry if it does not appear, just continue to with the guide.
then go back to the Partition and Encrypt tab.
Slide the Partition slider to the Left, and click on Start.
repeat the process and the "Complete setting disk partition!" dialog box would appear.
Check in My Computer that now you will only have One single memory drive for your player. Right click on it and select Properties, this is your actual real memory capacity.
Now check your player's Memory Info for the correct memory display.
To access this, go to your player's SYS TOOL >> MEMORY INFO.
Your player should display the actual memory size that you have just checked.
Check if the percentage is at 0%. If it is, you can skip Step 4 below, and continue to Step 5.
STEP 4
If your player's Memory Info does not show 0%, you will need to complete the below procedure.
Right click on your player's memory drive, and select Format.
Now a new windows format screen would appear.
Select FAT in the File System dropdown menu.
If after completing Step 3, your player really does have 4GB of memory, then you need to select FAT32 instead. As FAT only supports upto 2GB.
Click on Start to begin on the format process.
A warning will appear for the format, click on OK to continue.
Wait for a few moments while Windows formats your player.
When completed, check your player's Memory Info again, it should display 0% now.
STEP 5
Once completed, start copying music/video files to your player and enjoy enjoy your player. hope this helps
Dec 19, 2009 | Apple iPod nano
Tip
FORMAT ERROR IN MP3 PLAYER
STEP 1
STEP 2
STEP 3
STEP 4
STEP 5
on Dec 19, 2009 | Audio Players & Recorders
My USB cable can't be read
Upgrade the firmware by downloading the latest version of the Philips Device Manager from www.usasupport.philips.com and clicking on the Update tab.
-Tha Mp3 Doctor
Jan 21, 2009 | Philips SA3025/37 Flash MP3 Player
Firmware
Nov 27, 2008 | Audio Players & Recorders
Firmware problem
My problem
lucky - make sure you are not using MAC or Windows Vista. Make sure the software is installed. Try another usb port in your computer. Try a usb port on another computer with same OS.
Suji - Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 23, 2008 | Philips GoGear HDD6330 MP3 Player
Format error in LG MP3 player CM60022 ACT_V9.1.52
first, go here and download the utility:
http://mp3-player-utilities.software.informer.com/
Then:
You will repeat the process and the "Complete setting disk partition!" dialog box would appear.
Then Format again your player on Windows..
Jul 21, 2008 | iLO (2 GB) MP3 Player
HOW WILL I RESTORE MY FIRMWARE
If it is a "chi-Pod" or other generic MP3 player, youll have to get on google to see if you can find it, I dont even know if you can get a firmware dump off a friends same model.
Feb 13, 2008 | Televison & Video
Sansa Raphsody 250R 2GB
It is very dangerous in formatting the 16MB format of the device. After learning it a hard way, i also learned the the 16MB format is a second partition of your player where is installs the firmware of the device. Formatting it will ruin your player and it will never function again the way you want it to work.
Jun 15, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player won't start
You need to check your MP3 Player on another PC. If it still have the problem then you must return it for a Firmware Update. When any kind of USB Devices plugged and couldn't continue the launch (boot) step. Then you have to be sure that the MP3 Player (Or USB Device): 1) Has a corrupted component. 2) Needs Firmware update (Know as Device BIOS Update).
May 18, 2007 | Generic Memory MP3 Player
Electronics - Others Logo
183 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
