Question about Microsoft Xbox Console
A/v cable hi there, my question is about the audio video cable. i accedentally broke my cable when i move in to my new place here in the philippines. add to that is i can't find a shop here that sells av cables for the old or original xbox. the only av that is available here in the phils is the new av cable for the xbox 360'. i feel like buying it but i don't know if it will fit/work for my old xbox. hope you will give me a bit of advise with regards to this problem. thank you and more power.
    Genius:
  • 1,019 Answers
Sorry to dissapoint you, but they are completely different at the console end. both the same to T/V. either 3 x Phono ( red-white-yellow ) Or 21 Pin Scart.
Don,t buy the 360 lead, it won,t fit.
Whats ironic, is that most of the Original x-boxes were assembled in the Philipines.
Try e-bay, if you can,t get 1.
i,ll ship you one from the U/K.
Mike @ Compurepair.
Posted on Feb 25, 2008
Battery light indicates its not charging
Back to the shop. Or look in the manual. Next time you better place a problem like this in the category audio, or speakers. It accedentely? is between Digital camera's.
Nov 06, 2013 | Digix BT-100 Portable Bluetooth Wireless...
Throttle cable stuck
I would suggest that the reason the cable broke use that table was seized in the first place.To see if this is the case disconnect the cable at both ends and try to move backward and forward manually. If you are able to move the table at all then I would suggest getting either a new cable or one from the auto wreckers.unfortunately the only way that you can unsieze a seized table involves many hours of lubricating the old cable by shaking it in a solution of diesel or some sort of rust penetrator.Regards
Feb 19, 2012 | 1997 Mercury Mountaineer
It wont turn on the power works but i think the audio cord is broke idk i cant c a thing visually but the ps3 turns on fine
If you recently moved the PS3 to a different location or switched TV's you may need to hard reset the system due to the default settings not being in place.
otherwise its your HDMI cable. they tend to go bad rather frequently
Aug 21, 2011 | Sony Playstation 3 (PS3) Console
I have a denon avr-1602 and moved recently. The audio for the DVD player connected was perfectly fine before, but after making the new connections in the new place can get video, but no audio. I...
Hi matthewgk,
It's been a while since I have used my unit and it is not plugged in presently but this may work as I recall having a similar issue a couple of years ago. Try pressing the 'input mode' button on the main unit (or on the remote) to cycle through to AUTO rather than ANALOG. If you still have issues you could try cycling through the DVD remote menu (usually on screen) and selecting the input source type while AUTO is shown on the receiver.
Regards
Matt
Sep 16, 2010 | Denon AVR-1602 Receiver
No sound from the speakers
one of the most common ways for the speakers is to Accedentally put the input output cables in opposite of each other so try to make sure they are in right and then go to your control panel and then go to souds and audio devices
Jul 14, 2010 | Dell Latitude D600 Notebook
"Cannot display this video mode"
first thing check all power cables and monitor cables are plugged in properly , also you might check the monitor cable , inside the medal housing to see if any pins were broke off while moving. this would be an easy fix , just buy a new cable. if not check to see if you have a video card and that it is not moving around and properly seated to motherboard. if not most pc's are onboard video which would be entirely different issue. most of the time when moving pc's its usually a simple fix.
Apr 04, 2010 | Dell E153FP 15" LCD Monitor
I plugged in my Xbox 360 and then i moved it to a different wall then put it back to the original place it was in the beginning now the sound cant work
Check the audio/video cable. Make sure it's securely in the back of the TV and console. If you still have the same problem, hook your xbox up to another TV on which you know the sound input works. If the problem persists, you no know that it's not the TV but the xbox. You could purchase a new audio/video cable from somewhere like Best Buy. If the new AV cable didn't work, you could take it back to the store and then give Microsoft a call at 1-800-4MYXBOX. Good Luck!
Jan 07, 2010 | Microsoft Xbox 360 Console
Cracking sound from satellite speakers
Crackling is typical with dirty and/or loose connections in the speaker cable.
If you mounted or otherwise moved your speakers to position them while the speaker cable was connected then it's very possible that some of the threads broke or your connector is loose.
Dec 12, 2009 | Denon AVR-1508 Receiver
Microsoft Xbox Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
