Question about OKI C5100n Laser Printer
Replace Belt Can I bypass the replace belt error or am I requires to replace it. My printer prints great and I would rather not replace. Is there a master reset. Thanks
  • 15 Answers
The service manual says that when you get that message if you open and close the cover it will temporarily reset the message for 500 pages.
Posted on Mar 05, 2008
Ricoh gx7000 error code 993
This signal is triggered by the HVPS due to an accumulation of
condensation or ink spillage onto the transport belt.
?? Clean the transport belt.
Feb 28, 2014 | Ricoh Corp Aficio GX7000 GelSprinter Print...
Frayed & Broken belt found after printing stopped
You should be able to replace the belt yourself by takeing the printer apart, if your not feeling confident about it then you should take it to a pro. a service manual may be availabe.
Jul 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Error code c2257
the transfer belt has a cleaning system as part of the belt there is a motor in the machine that when the belt is installed runs the cleaning system which is to remove the old toner off the belt ready for the next print well the motor is burned out or the transfer belt cleaning system is messed up . Replace the belt if that does not fix it replace the motor worse case the motor is bad and it took the circuit board that controls it to
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 18, 2014 | Konica Minolta bizhub C450P Laser Printer
Printing blank
Sir, You have a registration error , which will require removable of the transfer belt and cleaning of the sensors below the transfer belt, recommended a tech do it, unless you know what your doing
Feb 12, 2014 | Konica Minolta bizhub C250 All-In-One...
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
Error code SC471
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
May 05, 2010 | Ricoh Aficio CL3500N Laser Printer
Menu screen comes up with (Replace Belt CG)
The 'Replace Belt CG' message on the 8008 indicates the OPC Belt (Green Reflective Belt which is located in the top of the printer) has reached the end of its life and needs to be replaced to ensure the print quality is maintained.
If you are happy with the print quality you can clear the message via the control pannel on the printer, you will however need to remember you have cleared the error in the future when print quality is reduced you will then need to replace the OPC Belt.
The ‘Replace Belt CG’ message can be cleared in the following way;
With the printer OFFLINE hold down the MENU button for 2-3 seconds until the display changes UTILITY MENU and then release the MENU button
Press the MENU button once more
The display will read "Utility Menu Clear Belt CG", press the MENU button once more
The display will change to "Clear Belt CG Not Execute" by pressing MEDIA/> key again the display will change to "Execute"
Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear belt CG"
Press the UP ARROW button twice to exit the Utility Menu
Press the ONLINE button to return the printer to the ONLINE state
The ‘Replace Belt CG’ message will now be cleared.
Jan 28, 2010 | TallyGenicom 8008 Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
OKI C5100n Laser Printer Logo
259 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
