Question about Ovens
Cooker not heating to rquired temperature
Lights come on inside cooker. Fan comes on but the temperature remains at nil.
Is this a probelm with the thermostat or could it be something else. The Cany man wants £96 just to come and have a look.
can you advise
Thankyou.
  • katsdaddio Jan 11, 2009
    GE JKP13GP oven takes forever to heat up. No error codes. Ohm readings 900-1000 on sensor. Elements read 30. Where to look next? Contol module?
  • 552 Answers
Your electronic control may be at fault. It receives a signal from the oven sensor probe tosence what the temperature is. The best way to rule out a possible bad oven sensor is to remove the 2 screws on the oven sensor (in the oven cavity) and pull gently on it until the wiring connector appears, then disconnect the plastic connector. Use your OHM meter to check resistance on the probe terminals. A probe at room temperature will register about 1040 to 1125 OHMs if good. If good, the electronics controlling the oven temperature would be the problem.
Posted on Feb 25, 2008
Hi,The cooker is cooking at a to higher temperature (either stays warm or when you turn up the temperature seems to cook at a very high temp. The fan works and when turn the knob, it clicks as if
The thermostat is working in that it supplies power to the heating element but it is not working in regulating the temperatures in between. Needs to be replaced/adjusted.
Nov 16, 2015 | Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
6200.5 fan works but no heat and light remains off
I suspect that from the symptons you describe that the fan oven element is faulty, the other possibility is that the thermostat is faulty, even if the element is faulty, the thermostat indicator light should come on.
Please rtate my solution.
Thanks.
Nov 08, 2009 | Kuppersbusch EEB62001 Electric Single Oven
My neff oven b1664 rear fan element stays on after switched off
I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
Dec 11, 2008 | Ovens
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
143 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
