The desolve scale have blocked the vibrating pump. You are write sometimes it can be unstuck by itself hoever this time is seems that more scale blocked inside the pump. If you know how you can open the pump directly and clean it with a wire brush. If you find it dificult you can try decalcifying solution once more and leave it for more time inside the machine so that more calcium will be desolve and probably you will have the pump unstuck. When you try to test the machine dont leave it work continuasly for more than 2 min cause this will burn the coil of the pump.
Please remember to vote for this answer
Please dont forget to vote this answer was helpful.
Many thanks
