Question about BMB NK533B MICROPHONE Microphone
Need parts for self-repair
Where can I buy internal replacement parts for this microphone? I need the threaded plastic part that connects the wire mesh bulb to the metal body. Thanks.
disneybob@netzero.com
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
Contact Beyer directly
They are generally good with parts support
Posted on Feb 27, 2008
Do I need acommon wire fom the main box
* Make, Model, Year, for specific solutions.
* Car + Trucks use the metal chassis or frame for grounding (DC).
* Heavy duty cable, wire may be required for Higher power rates needed to power equip (Starter, winch, direct wheel drive)
* Electric vehicles often have heavy duty cables connected to wheel drive motors. (85 Kilowatts for 1 hour on the Tesla 3)
* Fiberglass bodies needs grounding or common wire.
* I heard a rumor that military Humvee's also needs common wire.
* Sometimes a common wire is run to accessory lights, power sockets, switches, etc because the dash may be non-conductive plastic. Center seat console are usually plastic.
* Some of the very old classic cars use revers wiring. Special care needed to power up these.
* Newer computerized cars (with plastic frames) also need grounding protection from spark, RF sources, that may interfere with the digital equipment. (this may be in the form of a Faraday cage for real serious protection. (it looks like a wire screen mesh.)
Aloha, ukeboy57
Jul 27, 2018 | Cars & Trucks
I need to replace part #11000006 (on off switch) on my zephyr ZPY-E36S. Do you have one? Can mine be repaired (burnt out switch wires)?
-If only the wire itself burn then just replace the wire. You'll be okay. But if the switch it self totally burn, all the plastic around already melt down then yes it need to be replace.
-If you totally can't get the original one to replace, you can buy one from Lowes and modify to hole to accept it. It'll be okay as well.
Good luck
Mai
Jan 16, 2018 | Zephyr Kitchen Ranges
Changed my vents on fiesta for front spot light but I can't get them to work an iv tested the bulbs an there fine
You will need to run an earth return wire for the lights as the front will be all plastic . Run the wire to a metal part of the body.
Nov 09, 2013 | Cars & Trucks
I have two aries that have static on them
I am currently searching for support or repair/part replacement options for this microphone for which the problem in my case is very obvious. The capsule is cradled in a rubber mount which affixes to the top of the mic body by three plastic posts. One side of the capsule has a soldered wire, and the other is comprised of a contact pad that mates against a spring pin in the center of the top end of the body. Two of the three posts broke and there is not enough tension against the spring pin (also called a "pogo-pin") to maintain a solid connection. The connection is good enough most of the time for the sound to get through, however popping noise which is fairly random occurs as well. This situation can be easily observed by unscrewing and removing the windscreen and visually inspecting the mounting system. My thoughts if unable to get a cost effective repair made or replace the parts is to drill into the plastic mount and glue stainless steel pins of the same diameter (possibly from scrapped HDD mechanism or similar) in the place of the previously existing plastic pins.
Mar 06, 2012 | M-Audio Aries Professional Microphone
Diode needs replaced
If this is for an Alternator, it would depend on finding the parts. The diode is a one-way gate to regulate current flow. Depending if this is a Ford or GM and the age/style of the part, some are threaded in to the Diode Trio and then soldered.
If this is a Diode for a heater circuit, check with Radio shack to see if they can decode the capacity of the part.
Autozone.com will have Wiring diagrams for free if you register your vehicle with them. The output may be shown.
The days of self-repair for components are nearly gone. An electrical shop may be able to bench repair what you have. You used to be able to get internal voltage regulaors even at K-mart. Now most of the old mechanics are gone and so is the training to repair this stuff.
Jan 05, 2012 | Cars & Trucks
The small round metal mesh discs inside the kitchen tap have fallen out & will not stay in when re-inserted. Now the water squirts out at weird angles drenching the kitchen work surfaces. Do I need a...
Hi Jean,
These mesh discs and the part they go into - along with a few other small parts - make up what is called "an aerator".
Most aerators simply screw on threads at the end of your faucet. You can remove it by twisting it. You may need a wrench to loosen it first. Wrap the aerator in thick cloth / towel so that the wrench does not dent or scrape the finish on the aerator body.
Some aerators thread up and inside the faucet - rather than at the end - and need a special wrench to remove
Once removed, you should reassemble the parts and reinstall on the faucet. You may find replacement aerators in Home Depot, Lowe's, etc. if you're missing parts, etc. If changing it out, be sure to bring the old one with you to match.
I hope this helps & good luck!
Sep 22, 2011 | Microwave Ovens
My Epic 6500 power head will not turn on. Had to push the reset many times the last time it ran, and now it will not turn on. Help!
Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
Dec 22, 2010 | Electrolux Epic 6500 Vacuum
Disconnected wire in projection tv
The wire u though,cause ur problems.It nothing,probally been there all the times.It just a basic extra grounding wire came lose or ur tv got it service before,the tech.just didn't connected back in.
The problems u describing,Ur tv have Convergence Problems,it dead.U know how solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 31, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Left turn signal quits when brakes applied but only sometimes any ideals 1984 chevy g20 conver van only happens after brakes are applied for short time period
one of the bulbs has abroken filament and it connects to the other filament causin this concern replace lr brake light bulb and it will be fine
Aug 23, 2009 | Chevrolet Sportvan Cars & Trucks
Need diagram/instructions on how to replace primer bulb on briggs and stratton push lawn mower My primer bulb has busted so I'm trying to replace. Don't know how to get the old one out and replace.
Unless they have changed, all you have to do is unscrew the old primer bulb and screw the new one on in it's place. The primer is composed of the rubber bulb with a metal or plastic ring with threads on it where it connects in the fuel system.
Jul 17, 2009 | Garden
112 people viewed this question
Top BMB Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a BMB Audio Player and Recorder Expert? Answer questions, earn points and help others
