Question about GE GSH25JFR Side by Side Refrigerator
GE GSH25SGPA SS
This side by side is 4 years old and the botom of the fridge freezes and the top of the freezer is not cold. Also the water does not make is to the dispenser or ice maker I have got it to run through the filter and back to the water motor.
  • Anonymous Mar 18, 2008
  • Anonymous May 23, 2009
    I have the exact problem. I probably should have considered something other than GE
SOURCE: Ice maker won't make ice
One of your experts Dave, helped me determine it was the sensor that gives input to the motherboard telling it when to defrost. I believe it is called a thermosister.
Posted on May 21, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
  • 9 Answers
SOURCE: Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
Posted on May 01, 2009
suterman
  • 158 Answers
SOURCE: water not dispensing ,side by side gsh25sgpa
make sure the water line is not kinked behind the refridgerator.
Posted on Jul 04, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
Hi our ge refrigerator has freezer on top its freezing but not keeping foods cold in fridge.fridge is warm and theres two holes in fridge on top that keep freezing up.what should we do?
by the number on the refrigerator its a side by side,if the freezer is actually on top,then remove rear cover inside the freezer and the drain hole in the freezers plugged with mold take a wire and rat out this hole to get water to flow down the hole again
Aug 07, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a GE side-by-side profile 25.4. The fridge side is too cold and freezing items in back of top shelf and items in the veggie draw. Settings are 4 for freezer and 2 for fridge and things still are...
there is a air damper that lets the air in frome the freezer side,, it should be in the back top left corner on the fridge side turn the controls to off and listen you should hear a faint sound like a flap closing,, if not it is either stuck wide open, or the little motor has went out,,,( for a temp fix you can tape some of the opening off until you get the parts replaced
Jan 19, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Freezer fine, fridge too cold!
You need a new fridge side Thermistor. If that doesn't solve the problem, then replace the Damper Actuator.
Jan 05, 2018 | Zanussi Z32 / 5 Top Freezer Refrigerator
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
May 29, 2009 | GE GSH22SGRSS Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
479 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
