Question about Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160 won't print
It does not print from any computer that is networked to the Samsung CLX 3160. How do I get it to print. I have gone thru all the troubleshooting provided without online support until I was promted to go online. WTF.
  • 1 more comment
  • jozman3000 Feb 25, 2008
    I can scan and print that, but I can't print from my computer. The printer also says Scanner Locked, but it scans properly.
  • Anonymous Apr 14, 2008
    where is the lock??? and what does it look like
  • Anonymous Sep 08, 2008
    i can print but i can't use the copier and it always says "scanner locked". help
Why does my CLX-3160 printer says "printing.."even though i am not printing anything ?
Posted on Jun 15, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
1) You need to configure the IP address on the printer to get it printed thru network.
2) Scanner Locked, there's a lock underneath the scanner bed,make sure it's fully released.
Posted on Mar 14, 2008
  • 18 Answers
On the printer. Check under menu > Network> TCP/IP> If it comes up Static then hit the ok button to check the static address it gives you (should be 192.168.1.xxx). Make sure you don't change anything (use the back button to exit). Just copy it down. If it comes up DHCP then it is set up to obtain an address automatically. On your PC in Windows XP, Go to printers/faxes, right click the Samsung CLX3160FN and click on Properties. Click on the Ports tab. Check to see that there is a check mark next to standard TCP/IP it should say Samsung CLX-3160FN next to it (or not) (the name is only used to identify the port from others) and higlight it. Click on Configure Port. IF YOUR PRINTER WAS SET TO STATIC then the TCP/IP address here should match the address you copied from the printer. If your printer is set to DHCP but can't communicate with the PC you may want to set your printer to Static and set the TCP/IP address manually. you have to use 192.168.1 the last three digits should be higher than 100 and lower than 200. I have mine set to 192.168.1.104 and it is working fine. You just have to make sure that the numbers on the printer and the numbers under your port setup in Windows are the same. IMPORTANT: THIS ADDRESS HAS TO REMAIN UNIQUE TO YOUR CLX-3160FN AND MUST NOT BE DUPLICATED IN ANY OTHER DEVICE ON THE NETWORK OR IT WILL CONFLICT. IF THAT HAPPENS RAISE THE LAST THREE DIGITS OF THE ADDRESS TO STAY AWAY FROM ADDRESSES USED BY OTHER DEVICES. I have an HP laserjet and a print server with an Epson Photosmart on it also and I had address conflicts. I set them all on static with a unique address for each and now they don't collide and work fine. If you have to, you can set up a new port for your printer under windows. Same as above just click on add new port and follow the instructions. Again make sure that you use the same port number you have the printer set up under Static. I hope this helps.
Also check on these:
1) try using a different port on your router (sometimes ports go bad) If it is, get a new router.
2) try using a new ethernet cable, make sure it is Cat 6. For some reason these high end MF like that better.
3) Check the lights on the back of the printer next to the ethernet connection. You should have a yellow light and a green light. The green light should be blinking when it is communicating on the network. The yellow light should stay solid to show a connection.
4) Make sure your ethernet card on the PC is activated. Control Panel> Network Connections - depending on your machine there should be a local area connection that shows a couple of monitors with a tee connector and a cable with a lock going from one to the other. If it is dissabled it would have a red X accross the cable. If it does, right click on it and click on enable.
Good Luck
Posted on Aug 18, 2008
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I have a new samsung printer all in one clx 3180 fn, i installed her in my pc's through the installation cd and made the printing test over the network (wlan) everyting was ok. then i tried to scan a...
you need to delet the printer software from your computer and install it again, then it should work, if not download the driver's from samsung download page.
Apr 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
My Samsung CLX-3160FN has stopped printing colour. I have changed all the cartridges and it will copy in colour, but prints in black and white.
You need to check your document print settings on your PC. Drill through the printer properties menu until you get to the colour settings. At a guess you currently have it set to "Greyscale" rather than colour or auto.
May 03, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160 I put in a new black toner because the older one
This is the problem in the Black developer in the Imaging unit. Please call samsung or visit authorised service center
Nov 09, 2009 | Samsung CLX-3160 All-In-One Laser Printer
My samsung clx-3160 colour laser printer does not print very well.all prints are barely neglible and now most times no print or characters appear.I have installed new ink cartridges.Please advise.
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Jun 29, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
645 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
