Question about LG VX4650 Cellular Phone
No ringer The phone says that it's on carkit (which it's not) and will not ring or vibrate. It displays that a call is coming in, but you cannot hear anything. The caller also hears nothing. I have taken out and put back in the battery, restored to factory defaults and tried all call modes (driving, normal, etc.) with no success. It DOES ring if it is plugged into the lighter with the carkit adapter. I can't find anywhere to take it off of carkit mode.
    Problem Solver:
  • 4 Answers
You must have gotten moisture in your phone somehow. Take the battery out and dry it out with a blowdryer or pressurized air.
Posted on Dec 22, 2008
This not to fear in world
Posted on Feb 25, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
My iphone 5c will not ring how do I turn the ring ton me back on?
on the left side on the phone, theres a switch, turn it on
Oct 11, 2014 | Cell Phones
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Can the jitterbug ringer be turned off?
You can set your phone to Vibrate or silent mode so that the phone vibrates rather than rings. With the phone on and open, look at the inside screen while adjusting the ringer volume using the rubber volume button on the outside of the phone. As you adjust the volume, the inside screen will display the ringer volume level. It ranges from Max to Vibrate. Simply turn it down until the level reads Vibrate.
If you would like more step-by-step instructions, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Feb 14, 2011 | One Touch Jitterbug One-Touch Cellular...
The ringer doesn't ring, only vibrates. I select "settings" but there is not ringer volume level so I can hear the phone actually "ring', it only vibrates
First, make sure your Jitterbug is open and confirm it's on.
Next, Press the volume button on the outside of the phone below the Outside Display. Press the top of the button to increase the volume and the bottom of the button to decrease the volume.
There are several ringer options available to choose from. If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 and they will walk you step by step through the process.
Dec 27, 2010 | One Touch Jitterbug One-Touch Cellular...
LG AX390 phone does not ring, only vibrates
Mine will not ring... It just has a stupid female voice that says call from xxxxxxx call from xxxx and I can't hear the voice when I am operating loud equipment?????
Aug 02, 2010 | LG AX390 Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Thank you for visiting fixya
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
LG VX4650 Cellular Phone Logo
156 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
