Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Dishwasher not running
The dishwasher was in the middle of a cycle when my 2 year old either opened it or pushed a lot of buttons. The cycle never finished and now the normal light is blinking with a beeping sound. GE Trition mod# GS05560G02SS Whirlpool DU1145XTPB7 model. Normal cycle light started blinking sometime during end of wash cycle. It will not do anything.
Things I have already tried and not worked:
1. Unpluged and pluged unit back in.
2. System reset w/ heat-dry button, etc.
Any help would be greatly appreciated
  • 796 Answers
Hello sir.....
is the Start/Resume indicator flashing?
Opening the door or interrupting the power stopped the cycle. Close the door and press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
may be the motor has stopped due to an overload....as you have mentioned...many of the buttons were pressed...
The motor automatically resets itself within a few minutes. If it does not restart, call for service.
In Canada, call 1-800-807-6777, or your nearest designated
service center.
In USA ..Call the Whirlpool Customer eXperience Center
toll free: 1-800-253-1301.
If you need further assistance, you can write to us with any
questions or concerns at:
Customer Interaction Centre
Whirlpool Canada LP
1901 Minnesota Court
Mississauga, Ontario L5N 3A7
Posted on Feb 25, 2008
    Genius:
  • 3,422 Answers
Do you mean its not working at all?Or is it just that it is not washing and draining.
Waiting for your reply..
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Feb 26, 2008
    press START/RESUME?
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine....
when you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
May 15, 2010 | Asko 1385 Dishwasher
Cycle runs too long
long cycle most likely a heater problem.. or thermo problem.. to check heat run a cycle open the door in the middle of the cycle. is a lot of steam coming out... the dishwasher has to get to 70c to advance...if it is hot .then you could have a thermo that is not telling the control to advance the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more.
Sep 27, 2009 | Bosch 24 in. SHX33A02 / SHX33A06...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Feb 17, 2009 | KitchenAid 34 in. KUDP01FLSS Stainless...
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Buamatic dishwasher- cycle is not completing when running- gets stuck.
The fill valve may not be telling the unit that it is empty. Try pushing it down and see if it will restart.
Nov 29, 2007 | Baumatic 18 in. BFD47 Free-standing...
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
933 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
