MSN Explorer While attempting to login under windows XP on a Gateway e-series desktop. MSN explorer goes through all sign in attempts then stops every time. IE explorer and firefox work fine.
  • rklecker Feb 25, 2008
    Will this work for MSN Internet Explorer as well. This is where the problem occurs, when I click on my icon it sits and spins, sign-in attempts fail.
    Scholar:
  • 117 Answers
Uninstall MSN and reinstall. Make sure you uninstall it from
start/control panel/add/remove programs ...then go to
http://get.live.com/messenger/overview for windows live or
http://www.microsoft.com/downloads/details.aspx?familyid=e1fcdfbd-bdb1-44e9-b6ee-bf0ec49f393a&displaylang=en
For msn 7.0
Let me know if that helps...
Posted on Feb 25, 2008
How do I disable DOS mode and Wordpad from my computer?
i don' think that's possible.internet explorer proberly corrupt.
Mar 12, 2013 | Gateway LX6810-01 PC Desktop
When I use external storage devices like an sd card or jump drive, i constantly get a message that explorer has stopped working and shuts down. Why?
It could be caused by a corrupt sd card or jump drive due to removing it before the files have been written. If the devices are connected via USB, try a different USB slot. If explorer crashes and you can no longer see your desktop icons, press and hold the windows key and press R and release both. A run command will come up and type explorer.exe and your desktop should come back up.
Then go to My Computer or Computer and right click the device that is causing problems. Go to properties and under the Tools tab click Check Now under Error-checking. Make sure both Automatically fix file systems errors and Scan for and attempt recovery of bad sectors are checked, then click start. See if this helps your issue.
Hope this helps!
May 24, 2010 | Gateway M-6843 Notebook
My browser will not connect to the internet
Do you have any other internet enabled applications that are connecting properly? If you do have other internet enabled apps and they too are having problems than I would suggest trouble shooting your network connections.
If you are running Windows XP go "Control Panel" and under "PIck a Category" select "Network and Internet Connections". Next select "Network Connections". Right click your network connection and select "Repair". Windows will attempt to repair your network drivers, settings, and reestablish your network connection. If unsuccessful it will attempt provide an error message describing the problem.
If you don't see that option start checking connections along your network cable wiring. A plug may have come out or a cable damaged.
If it is not your network connection or your wiring it is your browser software. Reset your browser back to default settings to repair any changes made by accident by yourself or perhaps a website attempting a browser hijack:
Reset Internet Explorer to the default settings To reset Internet Explorer to the default settings
  1. Close any Internet Explorer or Windows Explorer windows that are currently open.
  2. Open Internet Explorer.
  3. Click the Tools button, and then click Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. Select the Delete personal settings check box if you would like to remove browsing history, search providers, Accelerators, home pages, and InPrivate Filtering data.
  6. In the Reset Internet Explorer Settings dialog box, click Reset.
  7. When Internet Explorer finishes restoring the settings, click Close, and then click OK.
  8. Close Internet Explorer. Your changes will take effect the next time you open Internet Explorer.
Hope this helped.
Feb 05, 2010 | Acer Computers & Internet
Internet Explorer 8 crashing when I login to facebook. Help pls!
Try checking what addons are running in IE, it could be a Software conflict , aslo update flash/java/shockwave
also, try loading the page through a proxy
https://cowclock.com
you can use the firstbar but it disables client side scripting
Glype works pretty well and CGI is java re-rewrighting
good luck!
Sep 04, 2009 | Microsoft Internet Explorer 8
Our email which is serviced by msn intrnet explorer has quit
some file in the system are corrupted probably by some mal-ware or some virus. do u have any anti-virus installed on your computer?
what i can suggest you is try accessing your e-mail from other browsers like Mozilla firefox or safari. or you can try reinstalling the internet explorer.
Mar 14, 2009 | Microsoft Windows XP Home Edition with...
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
When i type my password in and press sign in it doesnt sign in and then about 3 seconds after it says msn has stopped working and goes off
You may have to delete cookies on your browser.
Since MSN Explorer piggy backs on IE, you can then delete cookies on IE. Just open both MSN and IE at the same time. Then on IE, click on Tools> Internet Options> Delete Files under Temporary Internet Files. You'll get a prompt to Delete Cookies as well.
Or, if you're login as an administrator on your PC, you can just go to C:\Documents and Settings\User\Cookies, then delete all cookies.
Aug 02, 2008 | Acer Aspire L100 PC Desktop
MSN Internet explorer
Are you using MSN explorer with a "paid" account.
When did you start having this problem.
I'm assuming you can connect to the internet all other ways by using either internet explorer or firefox mozilla.
There are a lot of small issues that may be going on. More details are needed so please let me know everything you can, including your Operating System, PC or Notebook..etc
Feb 25, 2008 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
