Question about RCA CD Player/Clock Radio (RP5640)
Rca rp5640 unresponsive buttons
After being on for a few minutes all buttons on my rca rp5640 are unresponsive until i unplug and reset everything
  • garysum Jun 30, 2008
    On our RP5640 we lost ability to hear the TV band. Weatherband never worked. Now to get FM we have to toggle to AM then back to FM. Otherwise just static. Audiovox (RCA) said send back if we didn't by on the internet. How comforting. They offered to attempt a fix for $50 but we only paid $39 so guess we will look for something else. I was hoping there was a reset button.
I have the same problem. Not much luck finding help at rca. Will keep looking.
Posted on Jun 27, 2008
My Sony Blu Ray was working fine. I bought a used blu Ray it skipped and froze(the BD player was completely unresponsive) I had to unplug it to power it off for awhile. Then I tried watching Netflix and It...
There should be an option in your setup menu to perform a reset. Reset all settings to factory defaults and try it then. This will sometime sfix this problem. If not, then you are looking at a really expensive replacement main board that will cost you more than the unit is worth
Mar 25, 2015 | Sony Televison & Video
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
Jan 28, 2012 | RCA Televison & Video
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Jul 20, 2010 | Casio Music
I just purchased the RCA model L32HD31R. Everything works fine except that I can't remove the analog channels from the list. I get my signal OTA so no cable or sat issues. I go into the List Menu and they...
I had the same problem and finally sloved it. You have to leave the input channels ( Vid1, Vid2, SVid, Cmpt, HDMI, etc ) in the In Channel List. So push the INPUT button, go to VID1, press Menu, go down to List & Labels then check In Channel list. Do this for all the inputs and then run your Channel search again. I hope this works for you. It did for me.
Jun 20, 2009 | RCA L32HD31 32 in. LCD HDTV
RCA Mp3 M4208GR-B is entirely unresponsive
This Mp3 player is ridiculous! My husband and I each have one (purchased Dec 08) and by Aug 09 his froze never to turn on again. I thought maybe he got a lemon because mine was still just fine. As of Dec 09 mine is unresponsive as well. Pretty junky piece of equipment if you ask me. Sure it was only $50 some odd bucks at Walmart, but I would expect it to last much longer than a year - especially because I had barely even used mine. Ridiculous. My best suggestion... buy a different brand. Junky ole RCA needs to retire.
Mar 02, 2009 | RCA M4208 MP3 Player
My RCA RP-3765 clock is not setting itself right
manual is good for thise model
Feb 18, 2009 | RCA RP-3765 Clock Radio
I had the same problem with my TV, This is the way i fixed the problem i took a hammer and banged on the menu button a few times and know the tv works great!!!. Little weird huh:)
Jul 28, 2008 | Toshiba 35A44 35" TV
RCA P52960 R/P lost all controls..remote & panel!1 HELP
Hello ChupacabraV2,
This is a scene from some horror movie. I bet , if you unplug it, the TV will still be on!!....Just messing with you. Its been several days since you posted this problem. Please post update if there is any change. I don't think you have the TV on all this time. Let us know
Best regards
May 31, 2008 | RCA P52960 52" Rear Projection Television
Oven or smooth top will not turn on. breakers are good and it is plugged in.
Unplug the range. Wait a few minutes, then plug the unit back in.  Reset the clock per your user manual. A pdf copy of your manual may be available on line at the Magic Chef site or the Maytag site, since Maytag has or had a similar model.
Dec 04, 2007 | Magic Chef CER3725AA Electric Kitchen...
158 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
