Question about LG WM1814CW Front Load Washer
How to install the rubber gasket on the door
My LG is only 2 years old and I noticed a small puddle of water on the front. It leaks from the front seal. since there are no authorized LG service people in middle GA, LG was "kind" enough to sell me the gasket.
It now appears that you must have some special tool to reinstall this gasket. It is held in place by 2 steel spring banks that fit in a front and back groove.
Any suggestions
Donna
    Genius:
  • 1,554 Answers
See page 4-4
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Posted on Feb 25, 2008
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Rubber Gasket Torn
IT IS EASY :
1- IF YOU SUCCEED TO TAKE OLD gasket YOU CAN DO IT FOR THE NEW ONE
2- IT IS JUST A RUBER PEICE SO YOU CAN
3- LIKE YOU SAID a {spring securing OR CLAMP } USING A SMALL TOOL {SCREWDRIVER OR BLAYER } TO DISCONNECT THIS SECURING PIECE IN FRONT THEN
4- FLAP THE RUBBER TO INSIDE THE DRUM THEN
5- THERE IS ANOTHER SECURING PIECE HOLD THIS RUBBER WITH DRUM INSERT YOUR TOOL AND DISENGAGE THEN
6- NOTICE THE TRIANGLE IN THE RUBBER PIECE
IT IS THE MARK TO CONNECT AGAIN IN RIGHT WAY OR YOU CAN MARK BY A PEN
7- REVERS THE MANAR
YOU WILL REACH
GOOD JOB
Jun 18, 2009 | LG Washing Machines
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
LG WM1814CW Front Load Washer Logo
341 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
