Question about Panasonic NN-T993SF Microwave Oven
Door switch part number
The wire connector which connects to the door switch/cutout (turns off power when door is open) fried and i need to replace. The connector rund from the little black door switch down to the base of the unit, presumably into the motherboard. My problem is i have no idea what the actual name of this particular part is or the accurate part number. If there is a wiring schematic somewhere, i could easily identify it. Thanks for any help.
  • Panasonic Master
  • 9,098 Answers
Normally these use what are called "Postive Lock" terminals, but regular "FastOn" terminals in either 3/16" or 1/4" size will work just fine too.
They are available at most hardware stores and stores like Home Depot and Builder's Square.
It may be inline or right-angle, insulated or non-insulated. But none of that really matters as long as it will fit without interference or shorting.
You can take one of the old ones with you to match it up.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 25, 2008
  • William Miller
    William Miller Feb 25, 2008
    Sorry that photo got cut off - here's a better version:
  • William Miller
    Only helpful??
    Need more info?
Our GE microwave convection oven Model PEB 1590SM1SS runs when you open the door. What is the problem.
Its back feeding power due to a bad door switch and connections to the switch. You have to unplug it, then remove the front panel . Look at the door switches, they should all snap back up if they are pushed down. If one doesnt, it is bad. Also look for browned or burnt wire connection to the switch. Poor wires and connection are the number one cause of door switch failure. I upgrade the switches to a switch with 1/4 inch terminals, these dang microwave companies are using switches with little 3/16 terminals and they just do not hold up/
Sep 17, 2017 | GE Microwave Ovens
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
GE JVM1790 Convection / Microwave Oven has no power except control panel
Seriously, check those door switches again (especially the top one and bottom one). Check them in place with the door both open and closed, and make sure you have continuity in 1 case (door closed) and open circuit in the other case (door open). You probably need to pull off the wire connectors to make sure you are getting an accurate reading.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 08, 2014 | Microwave Ovens
Whirlpool accubake system E1 - F5 error code
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
You can usually find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag here.
Dec 10, 2012 | Whirlpool Microwave Ovens
Microwave not turning off when door opened during operation
It is likely a bad door switch or mount. See the help file here.
On some models, the door switches, fuses, and TCOs / thermal cutouts / thermostats must be checked, too. See photo below.
There should be a "mini-manual" (tech sheet) hidden inside the unit - behind the back, behind the control panel, or hidden on the left side behind the grille - which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 15, 2011 | KitchenAid Microwave Ovens
When I turn on my oven for cleaning it shows a f9 problem...could you help me with that
An F9 error code on a General Electric oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Things You'll Need:
  • Ohmmeter or multimeter
  • Phillips screwdriver
#step1
Disconnect power to the oven.
Step 2
Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
Step 3
Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
Step 4
Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation. Repair wires as needed if defects are present.
Step 5
Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
Step 6
Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
Step 7
Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
Step 8
Contact a certified repair facility if the source of the F9 code has not been discovered.
Troubleshooting the oven with the electric power turned on is a job for a certified technician.
Do not perform troubleshooting on the oven with the power connected. Personal injury and damage to the oven can result.
Aug 04, 2010 | Microwave Ovens
No power to control board
You replaced the control board?
Assuming the fuse & holder are good, then check the cavity thermal cutout and magnetron's temperature fuse.
If those and wiring are okay, the board's low voltage transformer should be getting power.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.)
We have the service / repair manuals for these models and have uploaded them to our site here and here for free download to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Let em know if I can help further, otherwise...
Jul 18, 2009 | Sharp Microwave Ovens
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Jan 18, 2009 | GE JVM1440 Microwave Oven
Panasonic NN-S567BAS Receiving power, No Waves
I would still suspect the top door switch. You would need to operate the switch to see if it clicks both ways and ultimately a test with a meter is required. If you don't have a meter, you can connect wires to a battery and a flashlight bulb, etc., and use that as a continuity tester. On the door switch, COM is common, NO is normally open, and NC (if present) is normally closed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find thew whole service manual (in sections) and order parts by entering your model number (without the dash) here: http://www3.sears.com If it's not the door switch, I would suspect the control circuit board (the one behind tghe keypad) and we repair these nationwide for only $39.95.
May 31, 2007 | Panasonic NN-S431WL 1000 Watts Microwave...
Panasonic NN-T993SF Microwave Oven Logo
97 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
