Back to:
Tags:
PC Laptops
Generic problem for all PC Laptops
Keyboard problems (by 4 users)
posted by bangaloreboy on Feb 25, 2008
I changed original 8GB Toshiba HDD to 20GB Toshiba HDD, reinstalled XP, find that certain keys give wrong characters, e.g. inverted comas about numeral 2 when I use shift gives @, and when I use shift and press @, I get ".
When i am using mail, the characters take very long when typing, to appear, this is after teh change of HDD.
Please advise, system otherwise works well.
ronnie
Comment by bangaloreboy, posted on Feb 29, 2008
I am sorry for the delay, just did not have a wordprocessor loaded.I installed Open Office writer. I have checked the key-functions and they seemed to have solved the problem of Shift-upper characters. THe keys now respond correctly. Thanks.
The second problem of slow typing when in mail mode is still there, although while typing in this box to add a comment, the data flows normally without any delay.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by billymax64, posted on Sep 16, 2008
Hello
I have acer aspire3000 notebook and when l press the hash key l get a UK pound symbol how can l get the hash symbol? l also have the " and @ mixed up but l'm used to them now.
thanks Wendy
Comment by Guest, posted on Apr 19, 2008
keyboard has changed and wrong characters appear when typing
Comment by huskymum, posted on Apr 06, 2008
Hello, I hope you can help me. I have the same problem with my numeral 2 key; when using the shift key and 2 I get the "@" sign and if I use the @ sign I get the " key. I have noticed a few other keys like my pound sterling sign and the hash key have totally moved and I can't find them. I did not do any software or hardware upgrades. I have been using the laptop for general use i,e, chatting and music and photos. I have looked in the control panel under keyboard and in regional and for the driver settings. But no luck, The keyboard setting just give info on cursor rates and under the hardware tab it tells me its a Standard 101/102-key or Microsoft Natural PS/2 and that it is plugged into the keyboard port and it is working properly. the driver date is 01/07/2001 and version is 5.1.2600.2180. When clicking the Driver File Details it gives two driver files. C:\WINDOWS\system32\DRIVERS\i8042prt.sys
C:\WINDOWS\system32\DRIVERS\kbdclass.sys
I have noticed during the past few days whilst my daughter has been using a well known messenger service that a third party has managed to get inside the text box and asks if you can accept files. It was accepted once, but the file would not open. It was only accepted as it was genuinely thought that it was from my daughters on-line friend. It turns out that she was also having the same problems. Still unresolved.
I only mentioned this as this is the only thing that has gone wrong in the past few days.
Can you help me ?
Kindest Regards,
Sara
Best Solution
posted on Feb 25, 2008
FixYa! (100)
wowser
Rank:Wiz Wiz
Rating: 84%, 90 votes
Please use control Panel -> Regional settings to add the correct region - and remove any unwanted ones. (Reboot may be required)
As for speed when typing emails - more info would be useful. like what email client. Is typing in a word processor slow?
Regards
Rating Locked! (?) bangaloreboy has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on keyboard problems:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
rafique
Rank:Wiz Wiz
Rating: 81%, 164 votes
dear bangaloreboy , this may be due to your shift key is having a problem. This is permanently pressed or the other key is having some problem . If you think shift key is not causing a problem please check the key board settings from contol pannel .
I donot think this is caused by changing the operating system.
Best Regards
rafique
Rating Locked! (?) bangaloreboy has rated this solution as Thanks for Trying
Thank You!
Solution #3
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I forgot to mention that after changing Regional Settings in Control Panel back to UK region, and deleting the US one which was loaded when the OS was loaded, the keyboard functions were returned to normal. Thanks
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #4
posted on Jun 10, 2008
Not Rated (0)
remmyjha
Rating: 100%, 1 votes
when ever i want to make use of the backspace key to delete item it is not working what can i do
Thank You!
Can you Help with these PC Laptops problems?
Compaq Evo N610C PC Notebook
i have a compaq evo n610c + multiport w200 with XP sp2....
HP HP Pavilion dv6000z 15.4" Notebook...
please.... it must be simple...
PC Laptops
Not able to run any DVD on my Laptop Latitude D610 whereas...
HP Compaq Presario V2000 PC Notebook
please help me, my problem is i have formatted my laptop...
PC Laptops
hello , i own a Fujitsu Siemens AMILO Pro V2035 laptop and...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
