Hdmi connections Dear Team of Experts, I have a digital tv mounted on the wall with the hdmi cable let into the wall. The other end of the cable goes to a dvd recorder. I am considering satelite tv and so that I do not have to let another hdmi cable into the wall for the satelite box can I only use one hdmi cable from the tv with a splitter to the dvd and satelite box? If this is possible will i lose any signal quality. Please advise on this. Thank you Martin.
    Sergeant:
  • 280 Answers
Not a good plan! Yes you will have problems . It is best to home run a new cable.
Posted on Feb 25, 2008
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
Setting up HDMI / DVI port as a selectable Imput
may i know the model and maker of the device you want to use a HDMI cable
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
I have a vga to hdmi cable for my acer aspire 3680, when I connect the laptop to the tv with the cable, nothing happens. neither device sees the other or even registers that the cables are connected. is...
VGA has only analog video signal. It is not digital and does not have any audio either.
HDMI is a digital connection standard with both digital video and digital audio signals.
A cable with a VGA connector on one end and a HDMI connector on the other still needs a converter box to convert the analog signals into the digital signals required for the TV's HDMI. Click on the following link to go to web page titled VGA to HDMI Cable - An Unfortunate Myth
http://vgatohdmicable.info/
Apr 21, 2011 | Acer Aspire 3680 PC Notebook
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
How can I hook up a panasonic home theater to my brand new LG lcd tv?
Your TV must have an HDMI connector. Please check if your home theater also has an HDMI connector - like this one:
If so, then all you need to do is buy an HDMI cable, and connect one end to your home theater, and the other to your TV. HDMI cables have a digital connection that carries both audio and video, so they are quite convenient. Don't forget to select the HDMI input using your TV's remote control.
Tip: HDMI uses a digital transmission scheme which is fairly robust (unlike analog transmissions), so a $5 HDMI cable will perform just as good as a $50 or $100 HDMI cable. Don't let those store clerks rip you off.
If your home theater does not have an HDMI output, then you must use the analog connections. Look at the back of your home theater and make note of the connectors labeled as 'Output' (both audio and video). You should buy cables with connectors matching those connections.
If you need more clarification on this subject, just ask.
Mar 02, 2011 | Panasonic Audio Players & Recorders
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Feb 27, 2008 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
