Question about Pioneer VSX-D509S Receiver
Volume Control The Master Volume knob does not control the volume correctly. When turning the knob the digital display responds correctly for 1 revolution then repeats. The volume sometimes follows, somtimes doesn't. The remote control works correctly. Dirty switch? Failing switch? DIY repair or send to technician? Thanks for the help!
  • 2 more comments
  • canuckred Sep 01, 2008
    Same problem but now the volume moves up and down randomly when playing basy music. Only the remote works as if the volume switch is touch it potentially goes full blast. Takin git to a repair shop to see if the unit is worth fixing and if not I shall dump it and buy a new one.
  • Anonymous Sep 01, 2008
    It's like the volume is stuttering
  • Jakob193 Feb 16, 2009
    Yeah, it jumps around when I turn it, and sometimes goes in the opposite direction.
  • Anonymous Mar 30, 2014
    when turning knob makes fluctuating volumes
The volume control shaft lube, over time and heat exposure, will flow down and corrupt the contact between the volume twister and the spring loaded sensor. Pull the cover off the tuner, locate the volume control and take out the two screws holding it in. It looks like a small circuit board with the volume twister attached.
The base of the twister is hooked to the circuit panel by four metal tabs. Pry these guys gently away and pull the twister free. There will be a metal disk at the end of the volume control shaft, and will have a goopy lube residue on the face of it that can be cleaned with electric contact cleaner or some other kind of solvent. Wipe it clean,(do not immerse) reattach, and test. Worked perfect for me.
Good Luck,
F
Posted on Jan 28, 2009
  • Jenni
    Jenni Oct 12, 2013
    I am having this trouble with my 509S. I tried to follow your instructions, but cannot get the cover off. I've removed the screws on the sides, and under the front. Am I also supposed to remove all of the tiny ones in back, too? Please help, this is not my area of expertise! Thank you~
Encoder board part # AWX7386 is no longer available to purchase. You can do one of the two things below.
1- purchase the Encoder knob part # ASX7004 from Pioneerelectronics.com, but you need to be able to desolder the encoder knob from the board assembly and the install the new one.
2- This is an easier option to do first. Disconnect the power on your receiver. Open up the top cover only on your receiver model VSX-D409. Remove and pull out the black plastic knob (volume control) located on the front of your receiver. Look behind the volume control and you see a small board with part # AWX7386. Open up the two screws on the board and gently pull out the board. You see a volume contron knob installed on the board. Gently use a small flat head screw driver and push away the 4 fingers that are holding the top cover on the encoder in place. Then gently pull out the knob wich seperates the knob assembly. The use Electronics contact cleaner (Can be purchased from Radio Shack). Spray and gently clean inside of the volume controller (also known as Encoder). Be very carefull not to bend the small fingers located inside the unit. Sometimes there are some gowee stuff inside that is hard to clean so you need to use the cleaner and spray few time. When dry, install the volume control back and push the small 4 fingers in place. Install the boad back, replace the top cover on the unit and plug the unit back in. Test it, and you will be very happy. Enjoy..........
Posted on Jan 26, 2012
  • Jenni
    Jenni Oct 12, 2013
I have the same problem with my 509S. Bought it in May of 2000. Has worked fine until the volume problem started to occur in 2007. Don't know the causes. Remote works fine. Decided to upgrade and sell the 509S since it was aging. Just upgraded to the new VSX1018.
Posted on Jul 29, 2008
    New Friend:
I am having this same problem with my 509S, and have tried to follow the instructions above, but can't figure out how to get the cover off! I've removed all screws, and it doesn't budge. Any thoughts?
Posted on Oct 12, 2013
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
When I adjust the volume, I'll turn the knob, for instance, counter clockwise to turn it down. It will go down a couple digits and then may go up again.
hi richard, seems as if your rotary volume control internal switch pins are wearing out. this is a typical problem on many units that use rotary/digital encoder volume controls. before replacing the control clean the face pins, or have the pc board checked for moisture damage, or have the solder joints checked on the volume control. cheers.
Jun 23, 2012 | Kenwood KDC-322 CD Player
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
Sound volume knob does't respond
Chances are that it's a digital volume control.
The fact that it turns down again means it's probably fixable.
Open it up (switch it off first), and fetch a soldering iron. Look around for wires that go from the volume control and see if any are loose connections/broken wires etc etc. Solder these again, and it should work.
If you don't fancy this, take it to a hifi shop and they'll fix it for you (there'll probably be a fee involved)
Jan 13, 2010 | Teac DCD2831 Mini Hi Fi System w/3 Speed...
Have difficulty with volume control on Delphi SkyFi. Turning volume knob produces a digital number of 1 to 3. Seems to work better after being warmed up. Can eventually get up to 12 or above. Anything I...
Do you have one of the original orange display SkyFi units, or a SkyFi2, or an XT? It sounds like you are using it in a boombox? The rotary dials do wear out on the SkyFi and SkyFi2 and there isn't much you can do - the knob may come off and you can spray in some contact cleaner, but that doesn't always work either. Using a remote control might be your only hope at this point unless you buy a new old stock unit off of eBay or the like. Good luck.
Nov 10, 2009 | Delphi Roady XT XM Radio Receiver
How do i set the time and remove the demo setting
Hello again johnworley6,
To set the time and/or cancel the demo mode, you need to enter "PSM" mode. Do this by pressing and holding the "sel" button for 4 seconds. Use the left/right rocker switch to select the item. Turn the "volume" knob up/down to change the item. Press "sel" again the exit PSM mode.
So to turn demo mode off: 1) Press and hold "sel". 2) Press right until "demo" is displayed. 3) Turn volume knob until "demo off" is displayed. 4) press "sel" again to exit PSM.
To set the time: 1) Press and hold "sel". 2) Press right until "CLOCK H" is displayed. 3) Turn volume knob until correct hour is set. 4) Press right until "CLOCK M" is displayed. 5) Turn volume knob until correct minutes are set. 6) Press "sel" to exit PSM.
Hope this helps. If it does, please rate as "FixYa".
Apr 25, 2009 | Car Audio & Video
Peavey floor monitor speakers
you can bypass the volume controller and use the master control. just take out the volume controller and splice the wires from there straight to master control.
Feb 23, 2009 | Audio Players & Recorders
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Pioneer VSX-D509S Receiver Logo
1,810 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
