Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Do I need a lamp/bulb?
Hey all.... I have a question. I have an older(5yrs) Sony projection TV that might be showing it's age of late. I receive over the air broadcasts from my HD tuner and most of the time.......the picture only fills the center part of the tv. Most of the time I have black bars on ALL the way around the picture. This varies depending on the aspect ratio of the station broadcasting. The problem is now when I watch bluray's with the 1:85 ratio or whichever it is that fills my entire tv screen......the part where my hd tuner normally displays it's picture is slightly darker. I can only see this on very bright(white/bright blue) scenes. Is this what is known as burn in?? Do I need a certian set of lamps? I just don't know if it's burn in or the lamps. Again, this is only noticeable during brightly lit scenes and is otherwise not noticeable at all. Is there a fix for this? Excuse my ignorance. I know the tv is old and down on quality and will be replaced when the time is right but for now.....it is bugging the shit out of me!!!
  • hrc600rr Feb 25, 2008
    Thanks so much, Bob. I was told it was the lamp but I assumed the lamp would effect the entire screen area and not just a portion. There isn't any way to help/fix this? I assume I will HAVE to buy a new TV?
    Novelist:
    Scholar:
  • 96 Answers
Hi, Yes this is what you call a burn in , sence the part of the screen was blank out for so long the rest of the screen used slowly burt in, depending how bright your setting was place at, this is also the same affect when people keep there tv on the same chanel were there is only wrigting and no movement or video game or famous for that. It wouldn't be the bulb , they only project light,
Regards
What About Bob
Posted on Feb 25, 2008
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
easyab
May 06, 2011 | Sony KDS-60A2000 60" HDTV
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
It seems as though my Sony HD tv's picture has gotten darker over the few weeks. Does the bulb need to be repalced?
IF it is over two years since it was replaced, this is the way that they fail---get darker just before they fail completely.
Average life span is 2,000 hours which works out to for most people about 2 years.
Google the model number with the word Lamp after it and you will find dozens of places to purchase a replacement---the lamp is meant to be a customer replaceable part.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My tv is on standby and will not turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Dark picture on wega lcd
Yes, if this TV has a bulb it is likely to be the bulb.
I am not familiar with this exact model, but other LCD Projection TV will show dim picture after some time. Expected life of the lamps is about 2yrs. After 2yrs the picture will become dim. After 5yrs I am suprised it is even working.
Dirt doesn't cause this problem unless your are a smoker or have the unit "literally" outside. DO NOT try to clean it or let someone tell you to do it because it will cause more problems than it fixes.
May 07, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Jan 02, 2009 | Sony KDS-50A2000 50" HDTV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
618 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
