Question about Tascam US-122 USB Audio/MIDI Interface Sound Card
Can't record in stereo
Hi, i just bought the tascam 122l and i'm not able to record vocals in stereo. i could not use cubase as i just didn't understand it. but i am using audacity. i read where the 122 has problems is this a machine problem for not doing stereo.. im considering taking it back for the yamaha go46 i believe is the name. i am a beginner by the way. thanks
I have a tascam 144 that came with cubase. I am not able to figure out Cubase either. I am a beginner and am trying to record my yamaha electric drum set with it. so far no luck at all.
Posted on Mar 30, 2008
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Low volume on tascam us-122L
tascam US122 I cannot record anymore... green USB light on tascam is flashing all the time very fast... why is that?
Nov 18, 2008 | Tascam US-144 Sound Card
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Computer freezing while using Tascam 122l
Hi
I would perhaps try to reinstall the drivers for the device, and be sure that under audio settings, you have the Tascam set as the default device. Try this and get back to me here if it still gives you problems.
regards
robotek
May 14, 2008 | Tascam US-144 Sound Card
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Burn CDs from Tascam US-122L
The answer is yes, but it may not work as simply as you think. You can't just save your Cubase file / mix and then send it to your recorder. You'll want to render down the song you have to one stereo .wav file and send that to burner as a wav file. (That's the quick way). Another option is to render each file you have seperately so acoustic guitar, bass, vocal, etc are all seperate tracks. So the answer is yes, a .wav file is the format for audio cds. You'll record your seperate tracks and then you'll have to mix down, render, or export them when you are done. In Cubase, use "export".
Feb 07, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Tascam US-122 USB Audio/MIDI Interface Sound Card Logo
346 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
