Question about Baby Gear
Removal of rear bumper
I am going to fit a tow bar to my car but it appears that I have to remove the rear bumper to do so. I know it is only screws but is there an easy way to do it?
  • 2,039 Answers
I never heard of somebody have to remove the bumper are you sure you have the right tow barre kit if you install our kit our gonna have a hard time putting the bumper back the tow kit gonna be in the way double check if you have the right kit they sell a kit for car or truck that desing to fit there
thanks for using fixya
pierre
Posted on Feb 25, 2008
How to Fit a Tow Bar to my Car?
get a professional tow bar fitter to do it
and wire up the plug
its a very good deal
takes about 30 min max and they do it day after day
and know how to take the rear bumper off in seconds
look locally for towbar mobile fitters or towbar fitting workshops
Oct 20, 2016 | Vehicle Parts & Accessories
Bmw sport x 3 removal of rear bumper to fit tow bar
Check out this uTube video which shows the removal process. You've likely missed one set of bolts.
https://www.youtube.com/watch?v=psPAE__egqI
Sep 01, 2016 | 2010 BMW X3
What is a towing eye? Where is it located?
Many cars have a "towing eye" located in the boot, that you screw into either the front or back of the car to tow it. It is a long bar with a thread on one end and a circular end on the other. The car with most likely have a small panel in the front and rear bumper bar that you remove, you then insert the threaded end of the towing eye and screw it in until it stops turning. If there is no panel in the bumper bar, then the location will be under the bumper bar somewhere and you will need to look for it. It is designed to avoid damaging the car when you tow it.
Feb 27, 2016 | Cars & Trucks
How do I remove rear bumper to allow tow bar to be fitted
Trailer Hitch Installation 2012 Nissan Juke Hidden Hitch
click on link,,,,video shows you do not need to remove bumper if u buy the right hitch
Mar 18, 2015 | 2012 Nissan Juke
Install tow bar
You can get a DIY kit easily. There are 2 basic types out there, one which mounts outside the rear bumper and is visible just below it, and one which mounts behind the plastic bumper and is not visible except for the tongue. This however requires fitting by removal and replacement of the plastic bumper, and complete removal of the steel core of the bumper to make space.
May 29, 2013 | 1996 Toyota Camry
How to remove rear bumper 1999 blazer
Hi there:
Check this Removal Procedure...
1. Remove the rear bumper step pads.
2. Remove the license plate lamps.
3. Remove the nuts and the bolts that retain the rear bumper impact bar to the bumper bracket.
4. Remove the rear bumper impact bar from the vehicle.
Installation Procedure
Notice: Refer to Fastener Notice in Service Precautions.
1. Install the rear bumper impact bar to the vehicle as follows:
1.1. Position the bumper impact bar on the bumper brackets so that the holes in the impact bar are aligned with the bracket holes.
1.2. Install 2 bolt plates and 4 nuts on top of the impact bar.
1.3. Install 2 bolt and nuts through the bottom of the impact bar. Tighten the rear bumper impact bar nuts to 90 N.m (66 lb ft).
2. Install the license plate lamps.
3. Install the rear bumper step pads.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 23, 2012 | 1999 Chevrolet Blazer
Need directions to fit towbar and wiring on holden captiva sx (2007)
there is a standard tow bar and a 2000kg for genuine tow bars
you need to remove both tail lights,the bumper bar and reinforcement bracket, spare wheel and exhaust hangars on rear mufflers, remove the tie down bracket on LHS chassis rail(dont need this or the bolts that hold it on), so you can then bolt in place either of the 2 tow bars.
genuine wiring patch harness for trailer plug is my suggestion since its plug straight into vehicle and interfaces with vehicle, goes in right hand rear compartment remove lid then remove box, interface connector for trailer harness is there.
instructions can be printed out from dealers if you ask
some new kits dont come with instructions in kits because information is on dealer computers
there is a template to print out to cut hole in bumper bar for tounge area of tow bar, uses centre square dimple in bar but its a bit wider.
Sep 05, 2011 | Daewoo Korando Cars & Trucks
Saab 93 bumper removal
It depends on what year your car is,
If it's the pre 02 car then inside the boot there are 2 M10 nuts near the tie down eyes, remove these and then pull the bumper tips outwards whilst pulling the bumper rearwards.
If its the post 02 car then remove the torx screws inside the wheelarch 2each side, remove screw from bottom edge of bumper near to wheel arch each side, remove 2 plastic nuts from lower bumper near spare wheel well, remove rear light clusters then remove the screws behind them, unclip ends of bumper from bodywork and pull rearwards.
May 22, 2009 | 2008 Saab 9-3
Romoving front Tow Bar...
Just have to remove the 3 bolts on each side of the bumper. Just move the rubber splash guards out of the way so you can see the bolts up under there. Make sure you use anti-seize compound on the bolts when you reinstall. You will probably have to adjust each side of the bumper bracket so it fits back on your Jeep, cause with the tow bar removed, there is a gap now.
Apr 08, 2009 | 1995 Jeep Cherokee
Removing rear bumper on Audi A4 1997 to fit tow bar
Did you get the solution to this, I have the same problem
Jul 07, 2008 | 1997 Audi A4
Baby Gear Logo
118 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
