Question about Edirol UA-4FX External Sound System
SD card on WK-8000
Have midi files loaded on card but can't play on keyboard. Screen display reads "No file" What am I doing wrong? I've had this keyboard for a year and still can't seem to get it to work. Help!
PLEASE
INTEX AUDIO SOUND DRIVER
4 CH YAMAHA E 210882
Posted on Aug 19, 2008
    Champion:
  • 411 Answers
1. Midi files must be Midi-0 format and have short ????????.mid names
2. Files must be within a special folder (directory) named "MUSICDAT"
3. After you press the SMF player button, you need to change from internal to card using the right arrow key first and then the down arrow key to select. The first file on the card will then be displayed.
4. You many then use right arrow key or + key or numbers to select your SMF.
I found that the maximum number of files on the SD card is 256 (from 0 to 255)
Reuel
Posted on May 22, 2008
Intex sound card yamaha-4ch drivers
Posted on Mar 14, 2008
Keyboard won't load flsh drive loaded with midi songs keeps saying no data ?
Jack your hard drive may not have a program that can read that type of file have you tried opening the flash from the windows drive screen and looking to see if the files loaded?
Feb 02, 2014 | Yamaha PSR-E433 61-key Keyboard, with...
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Aug 10, 2013 | Casio CTK810 61 Key Keyboard
Sd card is not able to read midi files
Get a supported SD card. 1GB is supported by most Casio Keyboard. You need to format the SD card in the Casio Keyboard.
Midi files must be located within folder called "MUSICDAT". Some models only support "type 0" midi files.
Aug 10, 2013 | Casio Music
I need to know from which sites can I download rhythms & tones which is compatable fpor my casio keyboard ctk 810IN
You can play back standard MIDI files from the SD card slot, or load them into memory via USB. However, it is not possible to add new tones or rhythms.
Sep 26, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have a key board which have a card ****..i do not know what is its function and how is this key board may use and what is te function of this card **** which card may be insert and plz guide me in...
You need an SD Card that is 1GB or smaller. Once you insert the card, it will ask you to format. The card can save 256 midi-files only.
The SD Card can be used to save/load songs, midi-files to/from the limited 4K keyboard memory.
If you have IDES driver & software, the software can load/save midi-files to/from the SD CARD to computer hard disk too.
Sep 01, 2011 | Casio KEYBOARD WK-8000
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I want to use my sd card to put my own songs and when i change the song from an MP3 to MIDI file using the program WIDI 3.3 Pro. When i put the MIDI file which is the song, into the Sd card and then into...
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Apr 05, 2017 | Casio Lighted Keyboard LK90STADMC
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Edirol UA-4FX External Sound System Logo
194 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
