Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Burning smell from frigidaire side by side black
We've been experiencing a burning smell when the refrig kicks on. It's plugged in all the time as it should be, but just started smelling as if wires are burning. Is this common for this to happen? I've only had this for 4 yrs
    President:
  • Frigidaire Master
  • 2,651 Answers
There is a defrost heater inside the freezer section, remove the back paanel from inside the freezer. lookin at the evaporator the u-shaped black heate wraps around under it, there are some peices of styrafoam( used for air flow) surrondin evap area, make sure none are hitting against heater assy
Posted on Feb 26, 2008
Smells like burning rubber
Good afternoon friend, thank you for your post!
I understand that you are receiving a burning rubber smell from your Frigidaire refrigerator. I would like to ask you some additional questions to better assist you. How long have you been experiencing this smell? Have you noticed any additional symptoms? How often do you smell it? With this additional information I can provide further assistance. I look forward to your response. -Matt
Aug 24, 2014 | Frigidaire Refrigerators
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Burning smell behind refregratot. After fan trggered there is burning smell like rubber burning.
First , clean the coils under the front of the refrig , with a vac . Then pull the refrig out and remove the back panel and check that the fan there in working . If not , remove any obstruction or replace the motor ( pt # 4387244 ) . If the fan IS working , then replace the overload/relay , which is plugged onto the side of the compressor ( pt # 8201786 (comes with instructions )) . Both are easily replaceable and will save you hundreds in repair costs . Note : Dirty condensor coils ( bottom front ) can cause the overload/relay to go out .
Aug 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
There is a burnt smell emanating from my freezer. The ice maker isn't making more ice. My freezer had been left ajar and there was freezer burn on several items. We shut the freezer and after two days I...
Pour about 1/2 cup of water into icemaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the icemaker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
Aug 18, 2009 | Frigidaire FSC23R5D Side by Side...
Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Jun 20, 2009 | Frigidaire FRT21H8 Top Freezer...
Freon leaked/exploded out of freezer causing major health hazard.
sound like a compressor burn out and leaked when freon burns it creates what is called fozgeen gas (not spelled correctly) a very pungent order you should be ok the gas was used in world war 1 fyi.
Jun 17, 2009 | GALAXY Microsystems 63702 Top Freezer...
After moving frigde and freezer quit.
Your compressor start relay has become loose or possibly defective.
Push it back on for a good connection.
Watch it when you plug the fridge in.
If it sparks replace it.
Mar 12, 2009 | Frigidaire FRS23KF7AB Side by Side...
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
Not Cooling and has burning smell
If you are looking for help, one must explain the problem in detail, described properly, for one one the internet to review. For myself, a would require more details of your refrig, to properly explain a resolution. Otherwise a general answer is not worth much. If you have the fully electronic temperature controlled unit, then the components can be easily chedked in 5 minutes, by the on-board service diagnostic computer. One needs to know the general operating knowledge fo the refrig, which is naturally available, since you operated it for some years. Anyway, a layman can check it out by doing what is natural. Since the refrig defrosted, it has shut down. Four years is too short for genral compressor defects. Put the power plug in and check for operating sounds. Just a few seconds. You mentioned smell (outside or inside), ket a paper tube, like a paper towel center, and sniff the evaporator motor, then the condenser motor. I will recheck later, and see if you want to continue, this troubleshooting. Regards fmauka
Sep 21, 2007 | Kenmore 53542 / 53544 Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
596 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
